Do the 308 GTS and 328 GTS use the same targa roof? | FerrariChat
Discussion in 'Technical Q&A' started by Wayne 962, Aug 28, 2005.
  1. Wayne 962
    Wayne 962 Formula Junior Rossa Subscribed
    Nov 27, 2003
    503
    I'm looking to purchase a used one, and I found someone who has a used 328 roof in good condition. But, I wanted to make sure that it was the same roof, and that they fit the same. I'm planning on having it painted body color to give it that GTB look...
    -Wayne
  2. Air_Cooled_Nut
    Air_Cooled_Nut Formula Junior
    Nov 25, 2004
    952
    Portland, Oregon
    Toby Erkson
    Is PP gonna start doin' Ferrari stuff? :D
  3. 4redude
    4redude Formula Junior
    Jan 13, 2005
    732
    Fungus Corner
    Brian Keegan
    Yes Wayne, the tops would be interchangeable. All the hardware is the same. The biggest difference will be in the headliner on the inside of the top.
    We have several used tops available. Is there a particular year/material you would like to match?
    Brian Keegan
    T.Rutlands
  4. jaturon
    jaturon Formula 3
    Oct 25, 2004
    1,599
    Bangkok Thailand
    Zane
    Don't forget to post some pics when you have accomplished that 'GTB' look!
  5. Wayne 962
    Nov 27, 2003
    503
    Apparently not true! The roof I just received from you guys does not fit my 1979 GTS! The front part of the roof is molded completely different.
    The blue arrow points to the ledge on my roof, the green arrow points to the ledge on the roof you guys sent me. It's much thicker at the edges, and as a result does not fit my car.
    -Wayne
  6. Wayne 962
    Nov 27, 2003
    503
  7. Huskerbill
    Huskerbill F1 Rookie
    Sep 6, 2004
    4,126
    Oconomowoc, WI
    Bill
    So Wayne at Pelican Parts owns a Ferrari.
    That's HERESY!!!
    I was a longtime Porsche owner and have bought from Pelican before. Thankfully not much as my cars ran WELL!!! :)
    But, like the other guy asked, is Pelican going to get into Ferrari Parts??
  8. Mike C
    Mike C F1 Veteran Lifetime Rossa Owner
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    Here's my example, including the redone rear quarter louvers:
  9. Wayne 962
    Nov 27, 2003
    503
    That's a great look. The problem is painting the sills to match the rest of the car - I was hoping to get away with just the roof, in case they messed it up.
    Anyways, seems that Ferrari modified the roofs in the later years to accomodate an updated roof seal. Earlier roofs need to be modified as well. I am thinking that I may keep this roof and do the mod, since the headliner is correct. I will post pics if I indeed decide to do it.
    -Wayne
