Does a 360 fit in UK single garage ?? | FerrariChat
Discussion in '360/430' started by spiderscott, Aug 18, 2006.
  1. spiderscott
    spiderscott Formula 3
    1,661
    Ratarossa HQ UK
    Ratarossa
    Anyone on the list managed to get a 360 into a single standard size UK garage ??
    According to my measurements it should do ??
    Picked up my 360 spider last night and am about to attempt to put it in the garage but it sure looks tight .... thinking of installing some mirrors on the far wall to assist, any other tips or pictures would be great.
  2. Giggs
    Giggs Rookie
    Jun 29, 2006
    26
    It sure does, very tight fit.
    Put carpets on the walls, to help you lever the door against..
    It's easier to reverse it in than park forward.
  3. Trax
    Trax Formula 3
    May 26, 2005
    1,383
    Douglas
    don't think so, the car is widest at the back
    go in forward using the mirrors as a guide
    adjust the mirrors so you look along the car and get the back in
  4. subirg
    subirg F1 Rookie
    Dec 19, 2003
    4,369
    Cheshire
    In my view, it's easiest to reverse in as you get a full rear view through the mirrors and once you've got the rump in, you can be sure that the rest of the car will slide home smothly as the front is narrower than the rear. Defo a good idea to have some sort stuff on the walls to protect doors when opening. Some soft stuff at the back of the garage also a good idea to stop you bumping too hard...!
  5. spiderscott
    1,661
    Ratarossa HQ UK
    Ratarossa
    #5 spiderscott, Aug 18, 2006
    Thanks guys, basically I had to drive in front first as I also have some shelving down the right side far end, soo much better to go in with the front narrow end of the 360. Basically I installed some mirrors down the end of the garage as planned and lots of carpet underley down the side walls and the spider fits in nicely.
    Was really shocked yesterday at how wide the 360 is compared to my old 355 and 348 which were no problem in the garage !!
  6. the_jay
    the_jay Formula 3
    Apr 26, 2005
    1,104
    Murrieta, California
    Jay
    Dang how do you get in and out of that thing!?!? Tight squeeze- beautiful car!
  7. judoug88
    judoug88 Formula Junior
    Dec 5, 2004
    590
    Marin, CA
    JD
    How did you get out of the car!? It looks like you can barely open the door...
    Edit - Looks like I got beat to the punch...
  8. spiderscott
    1,661
    Ratarossa HQ UK
    Ratarossa
    Ha ha yep its pretty hard, i perfected the movement on my previous 348 and 355 cars ... basically i have to turn around in the seat and pretty much crawl out of the small door opening. otherwise my last 3 have all been spiders so worst case i would leave the roof down and get out that way.
  9. 68rcodemustang
    68rcodemustang Formula Junior
    Aug 12, 2006
    506
    Houston Texas
    Mullet
    I sure feel sorry for you guys that have garages like that. Mine is 39 feet wide.
  10. TrentS
    TrentS Formula Junior
    Nov 22, 2005
    789
    South Florida
    Yikes... If I had a garage that tight I'd be moving! ;)
  11. allyduncan
    allyduncan Rookie
    Apr 14, 2006
    1
    SpiderScott,
    How wide is your garage door and also how wide is it inside?
    Just curious to see how it compares to my garage, that looks a really tight fit!! :cool:
    Ally
  12. riverflyer
    riverflyer F1 Rookie
    Nov 26, 2003
    3,583
    Mendocino, Ca
    wow, that is a scary fit. I have 8' doors and usually tuck the drivers mirror in to make the fit work. I just built a new garage with 10' doors just for that reason.
    The modern cars a very wide, maybe you should go vintage!! they would fit great and actually go up in value, what a concept!
    congrats on the purchase, fun car eh?
  13. enzo360
    enzo360 F1 Veteran
    Aug 1, 2004
    5,439
    Belgium
    Jurgen Durand
    Putting a mark on the wall also helped me to get my car in its spot. I just have to level the mirror with the mark. Helped me from bumping into things. Will also be measuring a lot when time is due to put a horsey in the garage.
    ps. congrats on the car
  14. SrfCity
    SrfCity F1 World Champ
    FYI, don't bother backing in you'll burn out the clutch twice as fast.
