Does a Capristo sound different on different 355's?? | FerrariChat
Discussion in '348/355' started by All ON U, Apr 9, 2009.
  1. All ON U
    All ON U Formula Junior
    Feb 25, 2005
    334
    London, UK
    Sonu
    #1 All ON U, Apr 9, 2009
    Hi everyone,
    The reason why I ask the above question is because I recently sold my F355 Berlinetta and bought a F355 GTS. I swapped my Capristo over but they just don't sound the same. I loved the sound of my previous car and I am quite upset that the new one sounds different.
    Can anyone shed any light. My previous car was a LHD F355 Berlinetta 1994 model with 69,000 kms. The replacement is a F355 GTS RHD 1995 with 41,000 miles. The reason for the change was summer is coming and I thought a GTS would be nice and the deal came up so I took the plunge!!.
    Here is a quick pic of the old and then the new! More pics to follow once the car has been given the treatment!
  2. zero
    zero Guest
    Apr 24, 2007
    776
    #2 zero, Apr 9, 2009
    Well the most obvious thing is that they are both 2.7s so thats good. Secondly has the new one got a set of Cats on and the old one had straight pipes? And is the by-pass working?
  3. All ON U
    Feb 25, 2005
    334
    London, UK
    Sonu
    Both are non cats. And the by-pass is working so that's why I am puzzled!
  4. zero
    zero Guest
    Apr 24, 2007
    776
    #4 zero, Apr 9, 2009
    Same straight pipes then?
    Ok then is the top "Y" exhaust cat the same as the old one. Because there are two types and both types fit the 2.7s. Although i dont know if this actually makes a difference.
    Have you considered the different sound you have may be down to the acoustics inside the different model 355s. What i mean is Capristo on a spider sounds way different to when its on a GTB from INSIDE the car. Could the difference be because with a GTS you get more of the sound than in a GTB because its opened more to the elements?
    Is the new car a lower mileage model? Maybe a car with higher mileage has a freer engine therefore a different tone.
    Other than that i am stuck with any more options. I look forward to reading other responces.
  5. All ON U
    Feb 25, 2005
    334
    London, UK
    Sonu
    Straight pipes yes. Now the cats I wouldn't know about.
    The difference is that the Berlinetta sounded more like a F1 car and the GTS sounds more like a grunt! Need to really get that sound back. I used to get everyone telling me that they loved the sound of the B!
  6. zero
    zero Guest
    Apr 24, 2007
    776
    If it grunting i would have said the by-pass valve but you say its working. Mmm
  7. J. Salmon
    J. Salmon F1 Rookie
    4,367
    VA
    There are some differences in the body regarding the berlinetta and GTS. Maybe there are differences in sound deadening? Both are 2.7s with straight pipes and working OEM bypass. Headers?
    Take the top off the GTS and see how you like it. Mine is sweeeeeet.
  8. Neonzapper
    Neonzapper F1 Rookie
    Oct 19, 2008
    2,580
    MD/FL/Philippines
    Mykol
    Capristos make different sound pipes - Capristo 1, Capristo 2, Capristo 3 (soft to loud). Maybe one of your cars has Capristo 1 and another car has Capristo 3 or some combination different from eachother.
  9. All ON U
    Feb 25, 2005
    334
    London, UK
    Sonu
    I removed my capristo from my old car and put it on the new one so its the same exhaust.
  10. SonomaRik
    SonomaRik F1 Veteran
    I'm betting on a belt change.....out of specs there
  11. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,976
    MD and NE
    Robbie
    No 2 cars are built identical---Could be alot of things. back in the day when the 5.0 Mustang was the rage, I had 2 as well as many buddies had them. Most of us had the exact same muffler, exhaust setup, but all had a different little sound to them. Even the auto cars versus the 5 speed cars sounded different with all else the same...
  12. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    #12 gothspeed, Apr 9, 2009
    +1 ........... after reading all the other posts ....... cam timing would affect sound a tad ............. as would low compression .......... :(
  13. cuneo
    cuneo Formula 3
    2,484
    I swapped headers from oem to Fabspeed and got a pretty big shift in tone. Not quite as screaming, but sounds more torquey, to invent up a word.
    Check them bad boys first.
  14. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    Sometimes intake differences can cause this. Even a different air filter is going to cause resonation differences. For example, my 348SS sounds different after gothspeed intake modifications, everything else the same. Thsi was the same for my M3. A new air box and air filter changed the exhaust note.
  15. All ON U
    Feb 25, 2005
    334
    London, UK
    Sonu
    Thanks for all the advice. I think that doing a cam belt chnage the timing will make the car sound better. Coming to think of it when I did the belts on my old one the car did sound a lot better.
    So looks like I will try a few options to get my original sound back.
  16. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    Another possibility is if the headers are mis-shapen internally due to excessive heat. One would not know this until they actually blow out or crack.
  17. Capristo Exhaust
    Dec 20, 2007
    152
    Sundern/Germany
    Hello All on U, Hello all together,
    we have such a situation already had a couple of times, the issue had damaged manifolds, perhaps, the exhaust valve does not open fully because a depression hose was leaking, the people have thought that opens the exhaust valve, they have heard a crying sound change, in reality, the exhaust valve had Not complete open.
    We measured performance header from USA to the dyno and have seen the original have works best, that was one reason why we have built no Headers from 355, it makes no sense what to build new, the original function very well.
    The reason they get broken is not a bad material that Ferrari used, there is a problem with the bypass and exhaust valve and exhaust.
    Our exhaust system is built with separate ways, and we also have a new exhaust valve built if problems occur then remain open and not as the originals.
    To provide a better service, we established Capristo U.S. Taurino Racing is the general agency for United States and has all the products in stock.
    www.capristoexhausts.us
    I apologize for my bad English.
    Ciao Antonio
  18. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    I've fitted quite a few of those Capristo valves now, the quality is exellent and no failures so far. I've seen original replacement ones fail in as little as a year!
