Does a Daytona have a rev limiter? | FerrariChat
Discussion in 'Technical Q&A' started by ag512bbi, Mar 4, 2019.
  1. ag512bbi
    ag512bbi F1 Veteran
    Nov 8, 2003
    7,722
    So. Cal
    Armen
    At redline, Does a Daytona have a rev limiter/governor?
  2. Rifledriver
    37,288
    Your right foot.
    sixcarbs, randkin, Qavion and 2 others like this.
  3. 375+
    375+ F1 World Champ
    13,879
    :D:D
  4. colombo2cam
    colombo2cam Formula Junior
    Jan 31, 2019
    840
    Ted
    the engine rebuild costs
    Qavion and 375+ like this.
  5. tazandjan
    39,318
    Mine did not. Be careful, though, the official redline is 7500 rpm, but the tach is marked for 7700-7800 rpm.
  6. ag512bbi
    ag512bbi F1 Veteran
    Nov 8, 2003
    7,722
    So. Cal
    Armen
    interesting... Thank you.
  7. colombo2cam
    Jan 31, 2019
    840
    Ted
    In my experience I have never had the feeling I was going to over rev it like in other cars. It lets you know when you are getting there. The gears are long and fabulous.
    Rifledriver and of2worlds like this.
  8. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,550
    Scottsdale AZ
    Stu Boogie
    Never been in a colombo but that timing chain must make quite the sound at 7500.
  9. Doctor Mark
    Doctor Mark Formula Junior
    Dec 15, 2005
    922
    Georgia
    Mark Gronsbell
    No rev limiter.
    ernie likes this.
  10. ag512bbi
    ag512bbi F1 Veteran
    Nov 8, 2003
    7,722
    So. Cal
    Armen
    Thank you
  11. Rifledriver
    37,288
    Not if everything is in good condition. The 2 cam cars valve gear is much noisier.
  12. tazandjan
    39,318
    It is a stretch to even call a Daytona's a Colombo engine. Owes more to the DOHC 290S, 315S, and 335S engines than the SOHC Colombo engines.
    Daytonafan, Rifledriver and 375+ like this.
  13. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,231
    Georgia
    Wade Williams
    Image Unavailable, Please Login Of coarse on a missed down shift it is just broken valves springs, broken valves, holes in pistons, bent rods, and all kinds of mayhem.
  14. colombo2cam
    Jan 31, 2019
    840
    Ted
    holy bits and pieces Bat Man - - - - - - - NOTE TO SELF - DO NOT MISS SHIFT
    Ferrari Tech likes this.
  15. 375+
    375+ F1 World Champ
    13,879
    Is the lineage perhaps Jano-Bellentani-Forghieri-Rocchi or close to that?
    Daytonafan likes this.
  16. Ferrari Tech
    Mar 5, 2010
    1,231
    Georgia
    Wade Williams
    That one cost a head, piston, rod, all the valves, springs, 12 liners (rusted from the coolant). Although today I would just repair the head. But in 1998 I actually found a good set of heads and replaced them both after updating the valves and valve job.
    colombo2cam likes this.
  17. tazandjan
    39,318
    375+- Affirmative, there is too much out there on Colombo vs Lampredi engines. Folks seem to think if the heads come off it is Colombo engine, and if the liners are attached to the head, it is a Lampredi engine. Colombo only worked for Ferrari for a short period of time and many Lampredi features were incorporated into the "Colombo" SOHC V12s fairly early in their lives and well after Colombo had left. Last engine that could realistically be called a Colombo engine is the 365 GT 2+2, 4.4 liter, SOHC V12. Even that is a stretch. Not in Wikipedia, though.
    Daytonafan and 375+ like this.
  18. Rifledriver
    37,288
    They were drifting away from his design during the 250 period.
  19. Motob
    Motob Formula 3
    Nov 11, 2003
    2,389
    Frederick, Maryland
    Brian Brown
    I had the throttle stick wide open on a 365 GTS (a 2-cam engine) during a test drive. When I pushed the clutch in to shift to the next gear, it pinned the tach needle, I'm sure that the engine revved to more than 9000 rpm. It scared the crap out of me, but caused no engine damage at all. These engines are very robust.
    I would bet that the missed down-shift mishap revved the engine even higher.
  20. Ferrari Tech
    Mar 5, 2010
    1,231
    Georgia
    Wade Williams
    Even the best can't take too much. I had a very expensive (read $45k) SB2 race engine that the driver took to almost 12,000. Left an exhaust valve some where in the grass near turn 10A at Road Atlanta. The interesting part was the in car video. 5 speed, from 5 to 2 to 3. It was so quick that he had no idea. It just started running rough. The tach memory however told the tale. The owner didn't let me have the in car video.
  21. ago car nut
    ago car nut F1 Veteran
    5,523
    Madison Ohio
    David A.
    Before the paddle shift and ratchet shifters in race cars, missed shifts could be catastrophic to the engine!
  22. daytonaman
    daytonaman Formula Junior
    May 1, 2007
    986
    Australia
    howard pigdon
    he
    Daytonas have relatively short chain compared to other 4 cams as cams are gear driven, not directly by tchain.
    Rifledriver likes this.
  23. Rifledriver
    37,288
    It was a great design and kept the chain to a reasonable length. It was the motor that should have been kept and that other disaster phased out.
  24. sixcarbs
    sixcarbs F1 World Champ
    10,572
    SF
    Which motor was a disaster?
  25. Rifledriver
    37,288
    C4/400/412
    The cam drive and cylinder head, carb lay out was terrible. Rumor was it was an Agnelli family member designed it for an engineering school project and it needed to get built. With the C4 limited to 500 units it was OK but the decision was made to keep it and discontinue the Daytona design. Excuses were made why, hood height etc but were excuses. If the C4 400i motor will fit, so will the Daytona. Daytona is narrower and just as low.
