Does anyone have any secrets to pulling engine studs? | Page 3 | FerrariChat
Discussion in 'Technical Q&A' started by Kevin Rev'n, Nov 13, 2015.
  1. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    #51 ernie, Nov 19, 2015
    Sometimes Vice Grips don't even work.
    This summer the pcv valve on my suv bit the dust. There were two bolts holding it to the intake manifold. One unscrewed just fine, the other popped the head of the bolt. "Great"! I was able to get the pcv valve removed, and thought I would just use the good ol' vice grips. Vice grips snapped on nice and tight, twist, twist, twist, *POP* the daggon bolt snapped again. So off came the intake manifold, and out came the drill. Drilled that sucker out, and retapped the hole.
  2. Rifledriver
    37,345
    That's me after lapping syncros.
  3. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    17,991
    wisconsin/chicago
    bo
    I have seen guys do it by:
    1) Putting the head into their barbecue (these have thermometers, easy to adjust flames, etc) for 15 minutes or so... Probably safer than a MAPP torch or oxy torch...
    2) Then apply ice to the stud or dip the stud in icecold water (use oven mittens to hold the head)...
    Also, someone mentioned drilling...
    I had to drill out a bolt in an old ford. The best Home Depot carbide/diamond tipped/cobalt/etc bits kept breaking...
    Went to a machine shop and bought some of their drill bits, 10 were $200... Looked no different than the ones I was using, had no fancy labels, etc...
    They carved out the bolt in one pass...and stayed sharp...
  4. Cyco
    Cyco Rookie
    Sep 11, 2005
    20
    Perth, Australia
    Chris
    Any time you have a steel part stuck in an aluminium part you can take the part and have it anodised.
    The part's sizing will increase by a hair's breadth, but the steel part stuck inside will be dissolved by the process.
