Does anyone in CA refurbish dual mass flywheels? | FerrariChat
Discussion in '348/355' started by MaseratiSD, Sep 1, 2023.
  1. MaseratiSD
    MaseratiSD Rookie
    23
    Los Angeles
    Philip
    My 1994 348 (single clutch plate) is starting to have trouble starting when hot, it's been diagnosed as the dreaded flywheel Kluber grease thinning out. Since MD Clutches has gone out of business, does anyone else sell a rebuild kit, or is there someone on the west coast that will take it apart and re-grease it?
  2. fatbillybob
    Aug 10, 2002
    28,989
    socal
    It is a simple but messy diy job.
  3. m.stojanovic
    m.stojanovic F1 Rookie
    3,222
    Serbia - Niš
    Miroljub Stojanovic
    Perhaps you can try googling for "ferrari 348 flywheel regrease kit".
  4. m.stojanovic
    3,222
    Serbia - Niš
    Miroljub Stojanovic
    Just found my records of the sizes of the flywheel o-rings:
    Large:.....................240 mm (or 242 mm) x 3 mm
    Small (12 pcs):.......8 mm x 1.5 mm
    You can buy the o-rings (viton) and the Kluber grease separately if nobody is selling a complete kit.
  5. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    You will want new bolts for the booth, the old ones sreetchand when reused they often bite into the booth housing and ruin it, it will be er seal grease will be thrown. There is also bearing in there that can be replaced.
    When the car is hot and operating temperature and you shut down do you get a rattle sound from your flywheel? If not it may be something else.
  6. MaseratiSD
    MaseratiSD Rookie
    23
    Los Angeles
    Philip
    Yes, I get the rattle sound and it's hard to start. Two folks in the know have heard it and said it's the grease issue. Thank you for the O-ring sizes that helps a lot! Hoping I can order the bolts from McMaster-Carr. Best Regards, MaseratiSD
  7. MaseratiSD
    MaseratiSD Rookie
    23
    Los Angeles
    Philip
    If you try and goggle vendors all that is out there are the MD CLUTCH folks in the UK who went bankrupt. They did lots of videos, very helpful if you can get all the parts, but I have not found a complete parts list here in Ferrari Chat. Several people mention replacing the bolts, but no mention of the exact size.
    best regards, MaseratSD
  8. m.stojanovic
    3,222
    Serbia - Niš
    Miroljub Stojanovic
    Maranello parts diagram shows the bolt sizes.
  9. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    #9 Ferrarium, Sep 6, 2023
    The bolt issue is not dimeter and thread pitch, that's all normal fare, can be found at home depot. The issue is length, 3 threads too many and it will bite into the voith and crack/ crush it and it will never seal and you will throw grease. In theory you could reuse the original bolts, or get new longer ones and grind down to length. Its entirely possible its a standard length bolt too, never checked I just bought new ones from MD back when.
    BTW the bolts are different for Single vs Double plate clutch set ups.
  10. m.stojanovic
    3,222
    Serbia - Niš
    Miroljub Stojanovic
    Maranello parts diagram also shows the bolt lengths.
  11. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  12. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Actually they had a death of one of the 2 partners who was the engineer and the other one was retirement aged as well so he decided it was enough and shut down the business if I recall.
  13. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,531
    Jeff
    308 GTB likes this.
