F8 - Does anyone know? Help | FerrariChat
F8 Does anyone know? Help
Discussion in '458 Italia/488/F8' started by 05F430F1, Sep 7, 2023.
  1. 05F430F1
    05F430F1 F1 Rookie
    3,600
    Fort Lauderdale, Florida
    Todd
  2. 05F430F1
    05F430F1 F1 Rookie
    3,600
    Todd
    One side popped right off but this side won’t budge
  3. Art138
    Art138 Formula 3
    Nov 22, 2007
    1,534
    Ft. Lauderdale
    Both acorn nuts need to be removed…take off each side engine covers first. That back panel should then pull off by bending each side so that the panel clears each of the horizontally positioned screws. I also picked my entire set {same as the F8 design} at MyRicambi. I cut into place more insulation as the extreme heat over time can discolor the CF. I was not comfortable with the thin insulation that came with the engine covers.
    05F430F1 likes this.
  4. 05F430F1
    05F430F1 F1 Rookie
    3,600
    Todd
    Ah thanks man and I just figured it out too- there’s a 5/16 nut on the passenger side and just took it off.. drivers didn’t seem to have to do anything.
    I did drop one of the little Torx bits down somewhere and can’t find it, even with a pole magnet — ugh..
  5. 05F430F1
    05F430F1 F1 Rookie
    3,600
    Todd
    Interesting about the insulation— I’m gonna just install as they are and hope I guess.
  6. 05F430F1
    05F430F1 F1 Rookie
    3,600
    Todd
    Hmmm. Pealing off the original seals/rubbers to stick on to the carbon ones doesn’t seem to be as easy as I was told- sh*t, I hope I didn’t have to buy the new ones
  7. Art138
    Art138 Formula 3
    Nov 22, 2007
    1,534
    Ft. Lauderdale
    I dropped one of the acorn nuts also lol. I reused the original seals; Once the side panels buttress against the engine bay frame, they snug up nicely.
  8. 05F430F1
    05F430F1 F1 Rookie
    3,600
    Todd
    I wonder where my torx bit went? It didn’t make a lot of noises- like it went click and that’s it— I’ll gosh around some more before I put the panels back on but hopefully it wont hurt anything.
    And ya, I just put some 3M tape along new ones and re-applied the seals to the carbon panels. Done and they’re ready to go back in.
    Certain order? Side first or back is prob ok?
    Thanks for the help and support bud
  9. 05F430F1
    05F430F1 F1 Rookie
    3,600
    Todd
    Son of a B*tch!!!! I just spent hours removing and redoing seals (and fishing for torx bit and a washer) and go to put them on and— they aren’t the right f’ing ones! Now what the hell do I do? So mad.. gotta wait months again for them to be made? Can I drive car like this without panels? So upset.
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login View attachment 3577721
    Seems to fit everywhere except over the intake tubes… arch is different
  10. Eric C
    Eric C F1 World Champ
    11,091
    St. Louis, MO
    Eric
    Where did you get them
    That sucks and yes you can drive without them... just keep it out of the rain..
  11. 05F430F1
    05F430F1 F1 Rookie
    3,600
    Todd
    MyRicambi
  12. 05F430F1
    05F430F1 F1 Rookie
    3,600
    Todd
    Waited a long time for them [emoji24]
  13. 05F430F1
    05F430F1 F1 Rookie
    3,600
    Todd
    I’m really hoping he got multiple sets in and just gave me the wrong ones (perhaps for 488) as he said F8 and Pista are the same but 488 is diff. Will see when he responds in the morning
  14. Eric C
    11,091
    St. Louis, MO
    Eric
    What brand are they? I wonder which car it's for? Obviously not the f8.
  15. Eric C
    11,091
    St. Louis, MO
    Eric
    That's what I was thinking too.
  16. Art138
    Art138 Formula 3
    Nov 22, 2007
    1,534
    Ft. Lauderdale
    Surprised they screwed up…..Denis doubled checked mine and unpacked to check for flaws ect. They should be able to fly in a set by fedex. If you drive it without the covers open the bonnet when you park it.
  17. 05F430F1
    05F430F1 F1 Rookie
    3,600
    Todd
    Why open the bonnet?
  18. MANDALAY
    MANDALAY F1 World Champ
    May 23, 2013
    14,651
    AUSTRALIA
    ANGELO
    Pretty amateurish of MyRicambi :(
  19. Viperjoe
    Viperjoe F1 Rookie
    I’d reinstall the trim panels, if for no other reason to allay any concerns regarding the effect of excessive direct heat on the Lexan.
    MANDALAY likes this.
  20. Eric C
    11,091
    St. Louis, MO
    Eric
    I could make that work. I got a Sawzall.
    pdxjim488 and mdrums like this.
  21. goachild2000
    goachild2000 Karting
    244
    Houston, TX
    Shardul Mehta
    blkdiablo33 likes this.
  22. 05F430F1
    05F430F1 F1 Rookie
    3,600
    Todd
    Ya def wrong part. Denis said he’ll call me this morning. We will see if there is a resolve.
    I’m still dying to know why I should open the bonnet if I have to drive it when I park it. Maybe he means to open the engine cover. Denis did say once the carbon is installed to pop the cover when I park to let the heat out more to help preserve the carbon from discoloring.
    I don’t see anything under the covers that is going to make more heat on the lexan. It’s not like the covers are there to absorb the exhaust heat, they’re just there to cover wires, hoses and things to neaten things up. And lexan can handle it, I’m sure.
    It looks kinda cool without them I guess- just wish I could find that Torx bit tip thing I dropped in there…. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  23. Eric C
    11,091
    St. Louis, MO
    Eric
    You can drive it. Just don't get in any water
  24. Art138
    Art138 Formula 3
    Nov 22, 2007
    1,534
    Ft. Lauderdale
    Yes I meant rear hatch….Denis will tell you also that to preserve the integrity of the CF color leaving the rear hatch/cover open after a hard drive is recommended.
    blkdiablo33 and 05F430F1 like this.
  25. Eric C
    11,091
    St. Louis, MO
    Eric
    Yeah. That will turn ugly real quick. The carbon fiber on my f430 yellowed and bubbled pretty bad.
