Does my fuel pump have a check valve? | FerrariChat
Discussion in 'Mondial' started by ownferraribeforedie, Oct 14, 2025 at 6:05 AM.
  1. ownferraribeforedie
    Aug 26, 2025
    41
    sarasota fl
    Jeff Stepek
    Recently purchased a 88 Mondial 3.2 cab with 67k miles, USA version. I have the hot start issue in that when hot, I have to floor the accelerator and crank the engine for quite some time before it starts. Fuel accumulator just replaced. I have no history of the installed fuel pump, but would assume with the high mileage that it has been replaced. I see that check valves are available.
    Attached are a couple of photos. I will in time do a pressure test and some other tests to determine the hot start issue.
    Question, does a property tuned and set up 1988 USA Mondial 3.2 ever start easily when hot? Honestly I am afraid to go anywhere where I have to shut off the motor for a few minutes to over an hour. So far I have been getting gas in a can and putting it in the car as am worried about getting stuck at the pump.
    Jeff
    ownferraribeforedie
  2. Alden
    Alden F1 Rookie
    3,762
    Central Florida
    Mine starts on the first tick every time, when I have had problems. It's been the startup fuel pump relay, replace both of these relays and check for burns on the wiring on the w connector.
    Alden
