Does the F355 have a air temp sensor? | FerrariChat
Discussion in '348/355' started by F355Bob, Dec 8, 2012.
  1. F355Bob
    F355Bob Formula 3
    I have a 95 F355. Does the engine have an air temp sensor connected to the ECU to tell outside temp for cold start enrichment?
  2. MicroFirm
    MicroFirm Karting
    Dec 6, 2010
    231
    Colorado
    Frank
    There is an outside air temp sensor under the drivers side mirror. You can see a little bump there compared to the passenger side.
  3. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    I believe the MAP sensor reads the FAI temp. You can read it off the OBD port witha proper scan tool
  4. F355Bob
    F355Bob Formula 3
    Is the one on the mirror for the A/C?
  5. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    Tim Dee
    Yes correct :)
