Does the turn signal lever return (after turning)? | FerrariChat
Discussion in 'Mondial' started by braq, May 31, 2015.
  1. braq
    braq Karting
    Mar 29, 2010
    227
    Hill Island
    Paul XXXcX
    Good day,
    now here is a little nuisance, when I use the turn signal lever on the QV, it does not return after the actual turn, which would be the first question, was it ever intended to do that like we expect it (as from other cars)?
    If not, then this is where it ends, however I vividly remember from old mercedes it was a very common issues and all it took was to (re) file the notches in the lever's mechanic (as i.e. describer here Datei:Rep-anleitung blinker.pdf ? /8-KnowHow),
    any thoughts on this?
    cheers
    braq
  2. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Yes it should return. U should hear clicks as you turn the wheel.
  3. braq
    braq Karting
    Mar 29, 2010
    227
    Hill Island
    Paul XXXcX
    thanks a lot, will investigate the mechanics, any hint/pic welcome,
    cheers
    braq
  4. dfranzen
    dfranzen Formula 3
    Aug 31, 2013
    1,577
    Ponte Vedra Beach , FL
    Don Franzen
    yes it should return
    when you engage it does it click and stay?
    does it click when manually return to middle?
  5. afterburner
    afterburner F1 Rookie
    3,470
    Switzerland
    Urs STEMMLER
    #5 afterburner, Jun 1, 2015
    May be the same issue as on mine - fixed with a strip of styrene and superglue years ago and holding up no problem.
  6. floridadoorman
    floridadoorman Formula Junior
    Jan 14, 2014
    392
    Florida
    Alex
    Urs....what type of "pull" is that in the picture thread to remove the hub? Looks like it was made for that specific purpose...
  7. afterburner
    3,470
    Switzerland
    Urs STEMMLER
    Indeed. Pressure put on, WD40, wait, then slight tapping in the puller and off it flew. It stuck like crazy...
  8. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    The Netherlands - NH
    Tijn
