Does this part work on 456? Shocker actuator gear. | FerrariChat
Discussion in '456/550/575' started by skl63, Oct 3, 2009.
  1. skl63
    skl63 Karting
    Dec 13, 2007
    228
    Melbourne, Australia
    Scott
    Hi,
    In solving the suspension issue on our 456, we have discovered that the small gear on top of the shocker is broken. It is not available from Ferrari (apparently) but Ricambi sell a part, but list it as for the 355. Will it fit the 456?
    http://www.ricambiamerica.com/produc...ucts_id=261324
    Scott
  2. technician F
    technician F Karting
    Sep 15, 2009
    57
    is the same as F355
  3. Mr Mezzanotte
    Mr Mezzanotte Formula Junior
    Aug 22, 2006
    654
    link don't work for me - have you got a part number please ?
  4. Mr Mezzanotte
    Aug 22, 2006
    654
    #4 Mr Mezzanotte, Oct 4, 2009
    http://www.ricambiamerica.com/product_info.php?products_id=261324
    for info... original complete part...
    Ferrari 456 GT - ACTUATOR ON THE SHOCK ABSORBER
    Part No. 158732 £617.10 from Eurospares.co.uk / £622 from ferraripart.co.uk
    Fits the following models : 456 GT, 456 GT Auto, 456 GT/GTA, 456 MGT/MGTA (def) 1998, 456 MGT/MGTA (prev), 550 Maranello, F355 ABS BOSCH/355 F1, F355 B/GTS/Spider Mo. 2.7, F355 B/GTS/Spider Mo. 5.2, F50
    skl63 - how did you find out you had a suspension problem ?
    I cannot tell any difference between the soft, hard, or medium settings on my 456GT.
  5. skl63
    skl63 Karting
    Dec 13, 2007
    228
    Scott
    Mr M,
    Try this URL. It goes to the part #SAG355
    http://www.ricambiamerica.com/product_info.php?cPath=457_99998&products_id=261324
    I know I have a fault, because the car is riding harder than a Billy cart in the rear. So much so that you hear rattles and noises everywhere. My 365 Boxer feels like a limo by comparison, really.
    It is at the moment a most uncomfortable car, not the true GT we should expect.
    We will probably re build the rear shocks and also check that the pressure accumulators are fully gassed as well. These two issues seem to be the most likely contributors to a very harsh ride.
    A missing actuator will probably render the adjustable settings inoperative as well.
    Cheers
    Scott
  6. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    #7 ferraridriver, Oct 5, 2009
    Taz, for less than $300 you can get a new Corvette actuator and with a half hours work have a new one. All you need is a fine tooth hack saw, some Devcon Plastic Weld, and a soldering gun.
    I use a Dremel cut off saw and a lathe to get a fine perfect cut, but it can be done with a hack saw if you're careful.
  7. tazandjan
    39,415
    Dave- I believe you and that is probably the best option. Not all of us are as good with a hack saw as you are, however. My efforts along those lines usually look like something a rat chewed.
    Taz
    Terry Phillips
  8. skl63
    skl63 Karting
    Dec 13, 2007
    228
    Scott
    I have now ordered an actuator from Dave, a retaining clip (PN142079) from Ricambi and an actuator gear (SAG355) from Ricambi.
    We will fit these, hopefully reinstating the adjustability. If required we will then service the shocks and perhaps the pressure accumulators.
    I will keep you all informed.
    Scott
