Does this selector shaft look right? | FerrariChat
Discussion in 'Mondial' started by Ned, Oct 3, 2024.
  1. Ned
    Ned Rookie
    Sep 30, 2023
    25
    Australia
    Ned Perro
    Hi everyone
    I decided on the weekend to drop my transmission pan to change the fluid and adjust the gear selector as my shifts were a little baulky at times especially from first to second gear. All was going to plan however when I got to the turn buckle to commence my adjustment and I removed the dust boot I noticed the shaft is off centre and almost rubbing against the exit hole. Is everyone else's shaft centred as it exits the cabin or off-centred like mine? Any ideas would be appreciated as I have come to a stop until I am confident it is correct (which I doubt)!
    Alden likes this.
  2. afterburner
    afterburner F1 Rookie
    3,470
    Switzerland
    Urs STEMMLER
    It seems a bit far off - are your engine mounts in order or is your motor leaning to the left?
    Ned and Alden like this.
  3. gunn
    gunn Formula Junior
    Aug 30, 2021
    319
    Gunn S
    Urs suggestion sounds like the most likely culprit. If it turns out that the linkage is bent (which seems far less likely to me to be honest) and you want a straight one, message me. I'm keeping the shifter and the transmission is gone but I should have all the pieces in between for an 83 QV
  4. Rifledriver
    37,075
    The engine would have to be half way into the wheel well to have the shifter that far off. I think it more likely the fuel tank was out and not well reinstalled.
    Ned likes this.
  5. afterburner
    3,470
    Switzerland
    Urs STEMMLER
    This passage is in the firewall in front of the fuel tanks, leading into the centre console. There is rubber bellow sealing this to the interior.
    Ned likes this.
  6. afterburner
    3,470
    Switzerland
    Urs STEMMLER
  7. Ned
    Ned Rookie
    Sep 30, 2023
    25
    Australia
    Ned Perro
    Thanks for all the replies, Afterburner I also thought the engine mounts may be sagged on the side in which the shaft is leaning towards, the shaft is definitely straight as I also had the centre console apart not too long ago and checked it.
    Rifledriver can explain a little more about the fuel tank scenario?
    I will loosen the engine mounts and jack up the left side of the engine just a little to see if this centres the shaft.
    Funny thing is the car drove great beforehand, no vibrations and very smooth just second gear was difficult at times. Thanks again for the responses it’s a great help!
  8. afterburner
    3,470
    Switzerland
    Urs STEMMLER
    Ned, on my car, the forward section of the shift rod (attached to the gear shift support) has got a bend in it. This bend is supposed to face up, not sideways or down (in which case it would rub on fuel tank cross feed.
    Ned likes this.
  9. Ned
    Ned Rookie
    Sep 30, 2023
    25
    Australia
    Ned Perro
    Good to know afterburner as that might be my issue. Its a low mile Mondial 8 so I dont really know why that section would have been altered or removed previously..
    Oh well looks like the centre console is coming out again to check, really appreciate all the help with this one folks.
  10. afterburner
    3,470
    Switzerland
    Urs STEMMLER
  11. Ned
    Ned Rookie
    Sep 30, 2023
    25
    Australia
    Ned Perro
    Ahh thanks afterburner for that I had intentions of removing my centre console today!!!!
    I report back hopefully with some good news, not a bad way to spend the weekend working on the car!
    afterburner likes this.
  12. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,664
    Argent/Brasil
    Guido
    No bent in mine ! But I have seen shift rods bent also...when people forget to remove it before lowering the subframe with engine...:rolleyes:
