Does transmission need to be drained to remove speedometer sensor on '84 308 QV? | FerrariChat
Discussion in 'Technical Q&A' started by chfengr1, Sep 14, 2019.
  1. chfengr1
    chfengr1 Rookie
    Aug 17, 2004
    9
    Connecticut
    Ray
    Hi,
    It's still not clear to me after 2 hours searching older speedo sensor threads if I must remove the transmission gear oil before removing the sensor p/n 116987 from my 1984 308 QV. It faces down. Help, please....
    Thanks in advance.
    Ray
  2. yelcab
    yelcab F1 World Champ Consultant
    Nov 29, 2001
    13,704
    San Carlos, CA
    Mitchell Le
    No, minimal leak.
  3. APA#1
    APA#1 Formula 3
    Nov 5, 2003
    1,311
    Central Florida
    Might be a good time to just drain and change the gear oil while you are under there if you have not done it for a while.
    waymar likes this.
  4. chfengr1
    chfengr1 Rookie
    Aug 17, 2004
    9
    Connecticut
    Ray
    Hi - thanks, both, for the swift reply. As I changed the gear oil in July, I'm happy to hear I should be able to not do it again so soon, only 150 miles driven since then.
