360 - Dome light switches inop | FerrariChat
360 Dome light switches inop
Discussion in '360/430' started by 78bonanza, May 16, 2019.
  1. 78bonanza
    78bonanza Formula Junior
    Apr 1, 2018
    341
    Jim Cear
    2000 360. Dome light comes on normally with opening and closing doors , but the two manual switches/buttons for regular dome light and the spot light do not work. They are the push on/ push off type. Bulbs good, switches click normally when pressed , wires all attached .
    Any ideas ? Couldn’t find anything in the archives here.
  2. mello
    mello F1 Veteran
    5,447
    CA Bay Area
    Steve
    Might be bad switches. Check for continuity on the switches with a multimeter.
  3. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,724
    Just East of Weird
    Bob
    Fuse?
    Sent from my iPad using Tapatalk Pro
  4. Ernieinky
    Ernieinky Rookie
    May 25, 2018
    30
    Matthew Ernst
  5. 78bonanza
    Apr 1, 2018
    341
    Jim Cear
    Regular bulbs . I’ll get a multi meter on it tomorrow
  6. JonM
    JonM Karting
    Oct 31, 2017
    132
    South Gippsland, Victoria, Australia
    Jon Maratos
    I had the same problem with mine. I removed the dome light from the car and pulled the switches apart and sprayed the inside with RP7 to try to clean the contacts. Only managed to get one working. The switches are soldered in, two pins on each switch. Not too complicated if you’re handy with a soldering iron. Alternative is to just replace the dome light. Look for the Maserati equivalent, much cheaper and exactly the same, so I’ve been told.
  7. 78bonanza
    Apr 1, 2018
    341
    Jim Cear
    Good suggestion ....I’ll do that
  8. FantasiaForest
    Feb 22, 2019
    32
    Jacksonville Fl
    Joe C Rudkin Ii
    Please post back if you have a fix or Maserati part number and price. I just bought my 2000 360 2 days ago and noticed the dome lights only work when the door is open the switches are inoperable.
  9. 78bonanza
    Apr 1, 2018
    341
    Jim Cear
    Multimeter showed both switches inop . Sealed unit , no way to access the internal mechanism that I could find. All plastic .
  10. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,948
    MD and NE
    Robbie
    I may have some, post a pic of them
  11. 78bonanza
    Apr 1, 2018
    341
    Jim Cear
  12. JonM
    JonM Karting
    Oct 31, 2017
    132
    Jon Maratos
    The Maserati part # is 383100123, but I've just checked on Eurospares and Scuderia Car Parts (both in UK) and they are showing as "enquire" so might be hard to get hold of. From memory, they were about US$100 when I last looked about 6 months ago.
    FantasiaForest likes this.
