DON'T FORGET TO CHECK THE OIL !!! | FerrariChat
Discussion in '360/430' started by LUCCA-7, Jun 29, 2008.
  1. LUCCA-7
    LUCCA-7 Karting
    Apr 24, 2006
    121
    California
    When I had my 2004 360, I would check the oil every 2nd or 3rd time while filling up at a gas station. The 360 would take no more than a quart of oil between the 5,000 mile services. I now own a 2007 430 with an average of 3+ quarts between a 5,000 service. In speaking with Ferrari of San Francisco (only dealer/service dept. in the U.S. owned by Ferrari), that is normal for the 430.
    For those of you who might not know: The oil must be checked while the engine is RUNNING and VERY HOT. I heard a MAJOR problem is a lot of people are checking the oil with the engine NOT running & COLD, then adding oil to have it later overflow . . . this my friend is NOT good! I have shared this with other 430 owners (who have previously owned 360's). After hearing this, they frantically check their oil to find they are 2 to 3 quarts LOW !!! The 430 (dry sump) holds 10 quarts of oil, so don't panic! I'm NOT a mechanic . . . just trying to spread the word . . . now go check your oil ;-)
  2. toggie
    toggie F1 World Champ Owner Silver Subscribed
    Nov 30, 2003
    19,036
    Virginia
    Toggie (Ron)
    Yes, I check the oil with the engine idling and after it is fully warmed up.
    One trick I do is loosen the oil cap before it gets red hot. Because that oil cap gets red hot and then cools every time you drive the car, it can get quite tight on its threads. It is a lot easier to get a good grip on it and twist it loose when the engine bay is cold compared to when it is red hot. So, I get it loose and then tighten it back up finger tight before I get the car warmed up. Works well.
    The other trick is to have one of those long plastic funnels if I'm going to add any oil. I add oil with the engine off. The farther away from the hot engine the better for pouring the oil. I always put in half of what I think it needs and then start up the engine again and re-measure the level. Worst thing you can do is overfill it. If you do, you'll know it when you start it up. Oil gets into the intake and makes a cloud of smoke. I've seen this done on a 360, not yet on a 430.
    My car rarely needs oil, at most 1/2 a quart. YMMV because I'm only driving it about 2k - 2.5k miles per year and I get the oil changed typically twice per year (once in the spring and once in the fall). So, each oil change tops off the oil level back to full.
    Biggest piece of advice is don't accidentally touch any part of that exhaust system when your checking the oil level - it is a hot piece of metal at that point.
  3. Testacojones
    Testacojones F1 Veteran
    Nov 3, 2003
    5,198
    Florida
    Luix Lecusay
    Now one more concern, and this is when measuring the oil level.
    You remove the cap and swipe it clean, but then when you put it back in where do you rest the cap before removing again to see the level?
    At first contact with the oil reservoir or play with it a little and let it fall at the spot just prior to tighten it?
    The book doesn't tell you and the dealer doesn't sound as if they are too sure also.
  4. SrfCity
    SrfCity F1 World Champ
    Nov 1, 2003
    10,142
    Orange County, CA
    This is what I do.
  5. rslpartners
    rslpartners Karting BANNED
    Jun 22, 2006
    59
    S.F. Bay Area
    What brand/type and rating vicosity of oil do you guys put in?
  6. toggie
    Nov 30, 2003
    19,036
    Virginia
    Toggie (Ron)
    Me too.
    I buy my spare oil from the local Ferrari dealer (FOW).
    I believe it is Shell 5W40 synthetic oil.
    I think it takes a total of 10 quarts when I do an oil change.
  7. racerdj
    racerdj F1 Veteran Owner
    Jan 19, 2003
    6,952
    Indianapolis
    DJS
    +1 here.
  8. reubenk
    reubenk Formula Junior
    Mar 5, 2004
    333
    atlanta burbs
    reuben k
    noticed that my 430 drinks it as well. plastic funnel, rag, and oven mitt are definite prerequisites for this procedure! also have a nice round scar on my leg about the same diameter as a 355 exhaust pipe... :)
  9. fc2
    fc2 F1 Veteran Owner
    Nov 2, 2006
    5,263
    Silicon Valley Ca.
    Frank C.
    As a former 360 owner and current 430 owner, I appreciate this thread.
    Frank
  10. WRX Shenanigans
    WRX Shenanigans Karting
    Feb 7, 2006
    59
    No VA
    You suggest checking the oil with the engine fully warmed up and the car idling....is this procedure recommended for all cars or just Ferrari's in general? Or even more acutely, just the F430.
    I have a lowly Subaru and have been told its best and most accurate to check the oil cold and with the car off. If you are doing it after a drive, turn the car off. Either way, there should be seperate marks on the dipstick for hot and cold engines....of course I've never checked the oil on a Ferrari before and I am unaware of its idiosyncracies...I was just curious to find out if there is a means of higher accuracy when checking my own oil.
    Also, checking the oil while the car is running, wouldn't you be afraid of splash back?
  11. Testacojones
    Nov 3, 2003
    5,198
    Florida
    Luix Lecusay
  12. RichardCH
    RichardCH F1 Rookie BANNED
    Jan 16, 2005
    4,661
    very interesting as you NEVER need to check the oil in a 360 or even CS, now why is that ????????????????????
  13. arcticsilver997
    arcticsilver997 Karting Owner
    Oct 27, 2007
    203
    Northern California
    I always seem to have a hard time reading the dipstick because of all the bubbles. Does anybody have any trick or advice other than to turn off the engine right before you check it?
  14. hardtop
    hardtop F1 World Champ
    Jan 31, 2002
    11,294
    Colorado
    Dave
    My 430 has never needed oil between changes, 11K and counting. Perhaps it's because I broke it in according to the recommendations in the owner's manual. I know most owners do not, especially if they do not intend to keep it very long.
    Dave
  15. RBK
    RBK F1 Rookie
    Jul 27, 2006
    3,105
    Calif and Nev
    Bob
    Although you may be absolutely right, many argue the factory drives the car hard long before we see it and therefore there is no break in required. Like you, I always break a motor in (maybe magical thinking) believing the car and I "need to get to know each other". Incidentally, my oil use, although I have never tried 11,000 miles without a oil change, easily goes 3,000 without need for oil. Best
  16. LUCCA-7
    LUCCA-7 Karting
    Apr 24, 2006
    121
    California
    You've been BRANDED ! . . . that's how they tell if you've been checking your oil :)
  17. toggie
    Nov 30, 2003
    19,036
    Virginia
    Toggie (Ron)
    My car came with 45 miles on it when new (picked up my 06 430 in Oct 06). So someone had run it around some. I've heard they take it around the track several times and local roads and rev it up quite a bit while doing so. I just hope the transport people didn't also have fun with it while it was waiting on the docks.
  18. WRX Shenanigans
    Feb 7, 2006
    59
    No VA
    Thanks, I really should have known that.
    As for breaking in the car...90% of engine "break-in" occurs in the first 20 miles on the vehicle. Those first 20 miles typically dictate future qualities of that particular engine (ie strong or weak, burning oil or not, etc...). It is also said that a "hard" break-in is recommended for those first few miles. The rest of the break-in period (about 600-1000 miles) should be treated rather delicate, with a run up the rpm band every now and then (maybe 3 or 4 times in the first 600 miles). Another important factor for breaking in an engine is to vary revs as much as 1000rpm as often as possible, do not cruise for any longer than a minute or two at the same revs (obviously no problem in a ferrari :) ). This procedure is true for econoboxes and race engines alike.
  19. LUCCA-7
    LUCCA-7 Karting
    Apr 24, 2006
    121
    California
    "get to know each other" . . . I love it . . . as this is what I've done as well ;-) as the 430 is a totally different animal then my 360! Factory mechanics say (with a smerk) that there is NO break in period (as it's done at the factory and on the back roads of Marinello). Just don't keep the RPM up for periods of time, until 600+ miles as the manual states! . . . as a side note, I did baby the car for the first 600+ "smiles!" :)
  20. hardtop
    Jan 31, 2002
    11,294
    Colorado
    Dave
    Mine has never gone more than 4K without a change but has 11K total. I know many people argue the factory breaks them in. Why then does the manual recommend a break in procedure? It would be interesting to compare oil consumption between cars that were thrashed from day as opposed to those who waited the recommended 600 miles. Most other makes require 1000-2000 miles for break in. I know for sure that some high performance motors use a lot of oil if not broken in properly.
    Dave
  21. vm3
    vm3 Formula Junior
    Apr 12, 2007
    728
    California
    Shell oil foams so it is impossible to check the level. I switched to Mobile and there is no more foaming.
  22. LUCCA-7
    LUCCA-7 Karting
    Apr 24, 2006
    121
    California
    Great Question . . . and the answer is ?
  23. LUCCA-7
    LUCCA-7 Karting
    Apr 24, 2006
    121
    California
    I recently asked a friend in Southern California . . . have you checked your oil YET? (2008 430 spider with 3,500 miles) He said, I NEVER had to check the oil in my 360 . . . I said check it! He just left a message on my cell stating 3+ quarts low . . . he could not believe it ! ! !
  24. Schumi76
    Schumi76 Formula Junior
    Feb 15, 2006
    329
    NC
    Marco
    +1
  25. 07F430Spider
    07F430Spider Karting
    Dec 5, 2007
    219
    Los Angeles, CA
    Christian
    When I took delivery of my 430, Ferrari of BH specifically told me to check the oil level every 1,000 miles after running the engine hard and, as stated before, make sure to leave the engine running.
    I have over 6,300 miles on it in 15 months and must have added 4-6 quarts myelf in addition to the 5K service.
    I sometimes forget to check regularly so I keep the oil visible in the garage as a reminder. Last thing you want is to let it run dry which apparenlty happens a lot I'm told by the service center.
