Don't Ignore - Case for 348 belt change | FerrariChat
Discussion in 'Technical Q&A' started by Jagbuff, Jan 17, 2007.
  1. Jagbuff
    Jagbuff Formula 3
    Jan 13, 2004
    2,267
    Site of US F1 Race!
    Franck
    #1 Jagbuff, Jan 17, 2007
    I posted a while back a complaint about noise coming from the front of my engine that would go away after a few minutes. It didn't sound like bearing noise but more little a rattle. I was tempted to blow it off and continue using the car. "Fortunately", the nasty weather in Austin gave me some extra time so I decided to pull the engine and investigate....
    Sorry for the poor pictures (used my kid's digital cam) but here is what I discovered. It appears one of the timing belt followers started rubbing on the belt to the point it got so hot and it melted the shaft on the plastic belt cover, got sideways and started gouging into the timing belt.
    I guess I feel lucky considering the possible outcome had I continued driving the car!
    Questions:
    Is this a common issue?
    What is the possible cause - seized?
    What is the purpose of the belt pad follower?
    Should they be replaced during 30K belts services?
    Comments?
    TIA
    Franck
  2. Rifledriver
    37,279
    Can't tell from those pics what happened but that piece is only used on the 3.4 motor. With the long single belt they have and the routing of the belt it has a rather small wrap on the intake pulleys. With the very long belt, no active tensioning device and short wrap it was to prevent the belt from riding up the teeth and slipping when the belt streches with age. It is supposed to be adjusted with an air gap to prevent contact under normal running.
    It has obviously been in contact with the belt for some period. Good catch, nothing good was coming from it.
  3. F512M
    F512M Formula Junior
    Dec 9, 2003
    504
    Houston, TX
    Jeremy Lawrence
    Wow!! Having just purchased a 348 I am glad that your story had a somewhat happy ending. Great choice to do the right thing and pull the engine.
    BTW...what jack system do you have? I do alot of my own work on my Ferraris and it would come in very handy.
    Jeremy
  4. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    JAGBUFF ---
    What kind / brand of car lift are you using there? Where are they available? It looks pretty slick.
    As for catching that potential grenade in time, all I can say is "Go out and buy a lotto ticket, right now, before it wears off!!!".
  5. Jagbuff
    Jagbuff Formula 3
    Jan 13, 2004
    2,267
    Site of US F1 Race!
    Franck
    Thanks for the insight.
    The lift system is Eagle Mid rise Scissor lift from Eagle Equipment, around $1700 including shipping. It's "portable" and raises to 50" - great for low ceiling garage (mine is 10') - low enough profile that is fits under the car. Makes the engine out a breeze, well worth the money if you can't fit a 2 post.
  6. fatbillybob
    Aug 10, 2002
    29,209
    socal
    get the metal covers then it will not happen and set the riders properly too.
  7. Jagbuff
    Jagbuff Formula 3
    Jan 13, 2004
    2,267
    Site of US F1 Race!
    Franck
    Sounds expensive - what is a good source?
  8. 4redude
    4redude Formula Junior
    Jan 13, 2005
    733
    Fungus Corner
    Brian Keegan
    I don't believe the 348's ever used metal or alloy timing belt covers, but there was an updated version of the plastic covers.
  9. Rifledriver
    37,279
    Thats only because you never had to sell replacements because they never broke.
  10. Ricambi America
    Sponsor Owner
    1989-1990 used the metal covers. My car has them.
    plastic began later. Metal, I believe is NLA as a new item. I have plastic sets sitting on the shelf at Ricambi, because they seem to always get brittle and break when folks remove them (unless they have the delicate touch of a surgeon)
  11. procure95
    procure95 Formula Junior
    Dec 17, 2006
    587
    PA, USA
    Giovanni (John)
    I am interested in the lift that you got. Is this the same one:
    http://eagleequip.com/page/EE/PROD/LI-LM/MD-6XP
  12. sparky p-51
    sparky p-51 Formula 3
    Aug 8, 2004
    1,375
    klamath falls, Or.
    steve
  13. cavlino
    cavlino Formula 3
    Mar 6, 2002
    1,740
    Ottawa, Canada
    Carm Scaffidi
    That lift looks like a really good deal!
  14. Organiser
    Organiser Formula Junior
    Jan 13, 2004
    922
    West Midlands UK
    Phil Haynes
    #14 Organiser, Jan 20, 2007
    Anyone got a spare set of the metal covers to sell??
    My Spider had a similar problem, rubbing noise on startup which went away and then just got worse. It was due for cambelts so out it came, found that the area around the water pump pulley was broken and was sitting on top of the pulley causing the noise. Belts and tensioners were fine, plastic front cover and camcaps are rubbish!!
    Regards,
    Phil.
  15. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    You would think that the timing belt cover on a $100,000+ Ferrari would last the lifetime of the car. That's just seriously ridiculous and inexcusable!! To take an aluminum cover and replace it with a cheap plastic cover - hell, Ferrari...why not make it out of cardboard?
    There was a lengthy thread a while back about the shoes for the timing belt. I don't believe we ever came to a conclusion about the proper way to set these up. There is nothing in the manual. But obviously the shoe should NOT be set up to cause wear on the outside of the belt.
  16. PassionIsFerrari
    PassionIsFerrari Formula 3
    Aug 15, 2004
    2,454
    I was wondering the same thing...How much air gap should be placed between the belt and the guide??
    And where does one find an aftermarket or upgraded timing belt cover???
  17. Organiser
    Jan 13, 2004
    922
    West Midlands UK
    Phil Haynes
    Unless you find a metal one, then that`s it, I`m thinking about making a copy in a Carbon and kevlar mix for mine.
    Regards,
    Phil.
  18. procure95
    Dec 17, 2006
    587
    PA, USA
    Giovanni (John)
    #18 procure95, Jan 22, 2007
  19. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    I mean no offense, so please do not take this personal, its just an observation. I am looking at the pics of your engine out of your car. I dont know what you have for records or service history, but it appears to be very dirty and oily, and shows signs of minor corrosion and rust. If the car had a engine out service within even the last 10 years and had been cleaned up as it would be expected, I just couldnt believe the motor would look that bad in that short of time. It does not appear to ever have been out before, and if not, you may in fact be a very very lucky man. That oil around the bottom would appear to be a crank seal, and was probably throwing some oil mist onto your belt, so if one thing wouldnt have gotten you, something else would have. More pics and perhaps some input from some other of the guys here as to what these motors generally look like between regular services might be helpful.
  20. BigTex
    79,399
    Houston, Texas
    Bubba
    Definately switch to antifreeze with distilled water, and maybe some Royal Purple "Purple Ice" treatment......
    You Lucky Dog!
    As much as the 308 guys fret about belts that 348 single system would have me lying awake nights! Even with the car turned off!
  21. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    Yeah, the 308 only wrecks half the motor when a belt strips. But on the other hand, the 348 has some real HP thats difficult to get very easy out of a 308. HP isnt cheap nor easy. Yes, very lucky to have caught this before it popped.
  22. BT
    BT F1 World Champ
    Mar 21, 2005
    15,291
    FL / GA
    Bill Tracy
    Another sweet upgrade for the earlier cars! Whatever the updates for the newer 348's are I think they are pretty much offset with the other changes (seat belts, seat design, cam belt covers) :D
    BT
  23. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
  24. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    The early 348's had some advantages and some disadvantages compared to the later 348's.
    Pros:
    dual clutch
    metal cambelt covers
    seat belts
    cheaper bearings/hub replacements for the wheels
    Cons:
    timing/oil system bearing weakness
    tranny bearing weakness
    Motronic 2.5/single TPS
    exhaust/dual mufflers
    weaker wheel hub design
    insufficient wheel offset/handling
  25. Juan-Manuel Fantango
    Juan-Manuel Fantango F1 World Champ
    14,801
    Juan
    I swear I read the most interesting article in SCM yesterday. The article said the timing belt issue was hogwash. No kidding. The three year rule is invented to rob you of money. Yes, I personally know people who have come out on the short end of things....but..
