Door buzzer-can I shut it off?!!?!? | FerrariChat
Discussion in 'Boxers/TR/M' started by bensonae, Aug 4, 2013.
  1. bensonae
    bensonae Formula Junior
    Apr 7, 2013
    284
    Tokyo, Japan
    Alex Benson
    With the key in the ignition in the on position my door buzzer annoys me when the door is open. Is there a way to shut the buzzer up? I know there are two buttons where the door pivots that control the interior light and buzzer when the door is open. I just want to disengage the buzzer as I find it irritating. Anyone have any ideas or quick/easy fix?
    Thanks,
    Alex
  2. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,547
    romano schwabel
    just unplug the buzzer
  3. bensonae
    Apr 7, 2013
    284
    Tokyo, Japan
    Alex Benson
    Where is it located?
  4. bensonae
    Apr 7, 2013
    284
    Tokyo, Japan
    Alex Benson
  5. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    While I'm no automotive engineer, I suspect the "buzzer" is located very near to where the annoying sound is coming from...
    vincenzo likes this.
  6. blown daytona
    blown daytona Formula 3
    Feb 6, 2008
    1,679
    maryland
    Same as above. Don't know if it is listed in the WSM but I would follow the buzzing noise to the source.
  7. bensonae
    Apr 7, 2013
    284
    Tokyo, Japan
    Alex Benson
    In schematics looks to be under dash near glovebox but it is not easy to pinpoint at all. the "guess" on where the noise is coming from is not so good. Any one know where it is?
  8. Steve Magnusson
    26,841
    Behind the fuse-relay panel -- item 13 here:
    Ferrari Testarossa (1990) Parts : Table 125 - VALVES AND RELAYS
    But I don't like unplugging it completely because you'll lose other functions -- brake warning light test at start-up, seat belt buzzer. Just remove/disconnect the AR (light blue-red) wire to disable the key-in-ignition function only.
  9. bensonae
    Apr 7, 2013
    284
    Tokyo, Japan
    Alex Benson
    Thanks! That was the answer I was looking for. Much appreciated!
  10. stsalam
    stsalam Rookie
    Mar 23, 2014
    3
    Dubai
    Could someone please post a picture of the exact wire that needs to be disconnected?
    Thank you!
