Door card attachment | FerrariChat
Discussion in '308/328' started by Saabguy, Aug 24, 2015.
  1. Saabguy
    Saabguy Formula 3
    Mar 28, 2012
    1,785
    Shreveport, LA
    Hi all,
    So I've been trying to right the wrongs of the speakers that were installed in my 328. It will end up it better but not perfect. I used the best interior shop around and the carpet piece just wasn't made right after several tries so I gave up. Next owner can fix it better.
    But here is my question and info:
    Where do the different length tiny screws go?
    There are three large (M6 - 1 x 35 mm) machine screws that hold the armrest to the door that go through the door card and into the door.
    There are 5 long length skinny screws with tapered washer
    There are 2 medium length skinny screws with tapered washer
    There are 2 short length skinny screws with tapered washer (Actually both are slightly different from each other in length)
    There is 1 short length larger screw
    I know that 4 long skinny screws go through the carpet and into the door
    I know that 1 long skinny screw goes into the top back hole of the door card and into the door
    There are now 5 holes left:
    1 at the bottom back of the door card
    2 at the armrest lower cover plate
    2 at the armrest upper cover plate
    Since both door cards have been messed with prior to my ownership I found both sides are different and I'm just wondering how it should be.
    Thanks all!
  2. BigTex
    79,407
    Houston, Texas
    Bubba
    I need to go look at my car, but IIRC the door arm rest mounts to studs.
    After that, the perimeter is screwed on with sheet metal screws/cone washers, and the speaker grill mounts with four small screws.
    The early cars may not be the same as the later models, so not sure how much this helps....
