door cards | FerrariChat
door cards
Discussion in '365 GT4 2+2/400/412' started by pks41805, Nov 8, 2007.
  1. pks41805
    pks41805 Formula 3
    Aug 4, 2007
    1,152
    Colorado Springs, Co
    Paul Sloan
    Last night I tried to remove the door cards. I thought I had all the bolts out, but there is one remaining that I can not find. The last bolt seams to be some were in the middle of the interior trim, can anyone point me in the right direction? My car is an 82 400, the window will go 1/4 of the way up then stop.
  2. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
  3. markcF355
    markcF355 F1 Rookie
    Jun 6, 2004
    3,493
    Schmeckelstan
    Mark
    Are you talking about the door panel?
    If so, did you remove the screw under the arm rest, slide if off and then remove the bolts into the door?
  4. pks41805
    pks41805 Formula 3
    Aug 4, 2007
    1,152
    Paul Sloan
    Mark, I found the bolt under the arm rest. Thank you.
