Door closing problem | FerrariChat
Discussion in '308/328' started by JFerrari328, Oct 19, 2016.
  1. JFerrari328
    JFerrari328 Karting
    Jul 11, 2016
    113
    MA
    #1 JFerrari328, Oct 19, 2016
    Hello,
    I recently purchased a 1988 328 GTS (Can be seen at another thread). The passenger side door has always been tough to close, you have to slam/push the the door to get it to close correctly, which is not good for any door. I gave it a slight jack adjustment, all body line and gaps are good. I adjusted the jam strike up a little bit, it seemed like it was hitting the alignment pin. Door still tough to close. I removed the door jam strike completely to look at the alignment and try to find the issue. With the strike not in place the door would not stay closed, I found that the door is getting bound at the front pillar. The weather stripping is compressed (see photos). The drivers side door weather stripping is not compressed.
    If I move the front of the door out the body lines will not line up.
    Any thoughts or help is appreciated.
    Thanks,
    J
  2. 308 milano
    308 milano F1 Veteran
    Jan 15, 2007
    5,328
    Montana
    Kim
    Check the Door hinge pins. Had to replace them on both my GTB/GTS QVs. Royal PITA to do without chipping the paint on the door but well worth the effort. Some of the best advice I've ever received here was, " don't get in a hurry". :)
  3. ME308
    ME308 Formula 3
    Nov 5, 2003
    1,550
    Munich, Germany
    Michael
