Door frame corrosion | FerrariChat
Discussion in '348/355' started by mshobe, Jul 9, 2018.
  1. mshobe
    mshobe Karting
    Mar 28, 2015
    112
    Seattle-ish
    I spotted some corrosion on the inside of the driver's side door frame yesterday; see attached photo.
    I suspect it's accumulated over years from water dripping down through the window seals, but I'm not sure. There is no matching spot on the passenger side.
    My questions:
    • Anyone else have a similar issue?
    • Do you think this is the extent of it, or should I be looking more deeply within the entire door panel for more?
    • If this is all there is, should I assume I can't spread further unless I do a lot more rainy-day driving? This doesn't seem at all structural, but it's obviously something I'd rather not have the opportunity to spend money to fix. :cool:
  3. Enzojr
    Enzojr F1 World Champ
    Dec 12, 2013
    14,001
    West of PDX
    Tomy
    Wow ......
    Can you take another picture and back it up a bit, I can’t tell exactly where on the car that is.
    The orange part looks a bit detached from the car, is it cracked (the metal) or does it appear to just be surface rust ?
    I would also investigate directly below this point to the bottom of the car.
    Water goes downhill so there might be other places that are hidden you can’t see.
  4. Dave rocks
    Dave rocks F1 World Champ
    16,048
    Orchard Park, NY
    Dave Lelonek
    Very easy fix. Fix it now before it spreads. Rust is like cancer....
    mshobe likes this.
  5. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,500
    SoCal LA/OC/New Mexico
    Tim Dee
    Yeah like they said address it now. use a corrosion stopper first. this metal is very sensitive to rusting. Something with that deep a spot takes a lot to stop not just a prime paint deal
  6. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    10,028
    CT
    Grind to bare metal. Epoxy primer, filler, primer, finish coat. If the metal is too far gone you may have to have to cut it out and weld a new piece in. Have a pro look at it. As has been said, if it isn't dome right it will just get worse and you won't see it under the repair. As they say, do it once, do it right.
    alexjack and mshobe like this.
  8. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,500
    Tim Dee
    I been waitin on this hear day LOL
  9. johnk...
    Jun 11, 2004
    10,028
    CT
  10. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,500
    Tim Dee
    I;m a pollack I laugh at myself everyday, better then coffee LOL :)
  11. mshobe
    mshobe Karting
    Mar 28, 2015
    112
    Seattle-ish
    Orange part is tobacco leather door panel - the photo is odd but it's properly attached in actuality, no cracks.
    I will definitely inspect the bottom now for more corrosion - water will indeed flow down to the lowest point it can reach and that's just more metal.
    Sent from my Pixel using Tapatalk
  13. tatry68
    tatry68 Karting
    104
    Chicago Suburbs
    Stan
    I"m one too and I say that if you can't laugh at yourself, you shouldn't laugh at anyone else
    SoCal1 likes this.
  14. hjp
    hjp Formula Junior
    Feb 23, 2013
    591
    Kansas City, Mo.
    Jerry Peterson
    If I am looking at this right, its the top rear of the door on the inside edge of the door itself next to the leather door panel. The rubber above this area covers the gloss black triangular window guide. The rubber should lap over the OUTSIDE of the metal, NOT the inside or it will be prone to leak water into the door. This is what may be at fault here. Check out the rubber and be sure it properly counterflashes over the metal.
  15. POLO35
    POLO35 Formula Junior
    Feb 21, 2005
    676
    Treasure Coast Florida
    MATT
    Just get on it with a very stiff rotary wire brush hit it with some Rust Converter which by the way turns black and then paint it with some black and you're done.
  16. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,500
    Tim Dee
    Stan from Chicago LOL I could have guessed
    I'll look you up next time I'm in Chicago to find good food :)
