Door handle removal | FerrariChat
Door handle removal
Discussion in '456/550/575' started by greg246, Apr 29, 2017.
  1. greg246
    greg246 Two Time F1 World Champ
    Jun 2, 2004
    26,599
    #1 greg246, Apr 29, 2017
  2. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Hi Greg - if it's not in the 575 WSM, I can post info from another similar model such as the 430. I'll be back at you when I'm at the shop.
  3. greg246
    Jun 2, 2004
    26,599
    Thanks, think I just found it in the WSM. My eyes must be sticky :)
  4. Graz
    Graz Formula 3
    Oct 15, 2012
    2,328
    New Jersey and Florida
    Graziano
    Greg, there are 2 screws under the arm rest. Once removed lift the arm rest off. You'll find 2 rods with adjustable nuts attached leading to the the door latch. You'll have to unscrew those nuts to remove the latch. Take a photo before you touch anything so when you replace it you'll reproduce the position of the rods. Good luck.
  5. greg246
    Jun 2, 2004
    26,599
    Thanks, I'll have another look tomorrow
  6. au-yt
    au-yt F1 Veteran
    Aug 13, 2006
    5,838
    Burradoo... Actually
    Graeme
  7. Konadog06
    Konadog06 Formula Junior
    Aug 22, 2007
    963
    Daytona Beach, Florida
    Bill
    #7 Konadog06, Apr 30, 2017
    Greg if my memory is correct removing the armrest on the 575 makes no difference. Remove the pocket, six small screws, and you should have access to everything you need. From here it's much easier to release the two rods with the yellow plastic clips. Its simple and you don't lose any adjustment. Push down or rotate up on the plastic clip, rotate it and slip the rod out.
    At some point you will need to unscrew the one rod from the door pull handle itself, make careful note of the original location/position so no further adjustments needs to be made when you reassemble. I think once these rods are released, the actual assembly removal of the door pull is at the top under the pull lever, one fastener. Provided some pics below.
    Apologize for multiple post, using an I-device for this posting.
    Couple further notes, to remove the drivers door mirror controls, afaik the door card/panel has to be removed. And to remove the door card/panel the WSM is lacking. I've removed everything as it instructed and still the panel remains firmly attached. Have yet to master this.
    If you have any questions, feel free, removed my door pull levers for Sticky RX repair six months ago.
    Bill
    FL
  8. Konadog06
    Aug 22, 2007
    963
    Bill
    #8 Konadog06, Apr 30, 2017
  9. Konadog06
    Aug 22, 2007
    963
    Bill
    #9 Konadog06, Apr 30, 2017
  10. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,952
    MD and NE
    Robbie
  11. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    It was nice of Mike to create those videos prior to sending the parts in to us to refinish. Thanks again, Mike.
  12. Konadog06
    Aug 22, 2007
    963
    Bill
    #12 Konadog06, Apr 30, 2017
    Dave only thing I see similar to 575 is the single fastener under the actual
    lever.
    Posting two more pics. Here is the door pull assembly view with door pocket removed, armrest still in place, yellow clip is one point where rod is unclipped.
    Bill
  13. Konadog06
    Aug 22, 2007
    963
    Bill
    #13 Konadog06, Apr 30, 2017
    Second removal point of rod with plastic clip is at this point. Removal of spring tension makes it easier. Make note of locations for spring and positioning of rods for reassembly. Also once this rod is unclipped it will be unscrewed from the door pull freeing the door pull for removal with the one fastener from above. The depth position of the rod into the latch should be noted for exact positioning upon reassembly.
    *Noticed the picture in post 7 above is actually upside down.
  14. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Thanks, Bill. Greg is asking for a 575 for sure as we are discussing his refinishing. As always - I appreciate your help.
  15. 285ferrari
    Sponsor
    Sep 11, 2004
    20,952
    MD and NE
    Robbie
    smh.......
  16. greg246
    Jun 2, 2004
    26,599
    Thanks for the input guys. I removed the door pockets last night and will attack it again when I get home tonight. I'll post some pics later too
  17. greg246
    Jun 2, 2004
    26,599
  18. greg246
    Jun 2, 2004
    26,599
    Excellent, thank you!
  19. greg246
    Jun 2, 2004
    26,599
    #19 greg246, May 1, 2017
    Bill, thank you for the instructions. The handles came out very easily
    So, in summary
    1. Remove the 3 screws at the top as well as the three screws at the bottom of the door pocket
    2. The pocket will pop out with some gentle force
    3. look underneath the handle and you will see a yellow plastic clip holding a rod. Unclip and the rod can be removed from the handle
    4. follow the second rod to the back of the door and you will see a black clip. I didn't need to remove the spring, the clip and rod unfastened easily
    5. detach the electrical connector to the handle
    6. lift the handle and undo the single screw at the base of the handle
    7. slide the handle and 2nd rod which is still attached through the hole in the handle well
    8. mark the position of the thread of the 2nd rod where it meets the handle (so it can be put back in the same spot)
    9. detach from handle
    10. Wash hands! :D
    Cheers
  20. Konadog06
    Aug 22, 2007
    963
    Bill
    Greg, glad to help. Well done on the summary. You will be very happy when your parts come back. The only regret I had was at the time not getting the mirror controls out and off to Dave at the same time. Even though they weren't sticky yet the restored pieces come back so nice they don't match well. Tolerable but not preferred. My car is due for a belt change next year and I plan to complete the job at that point with a little assistance.
    Bill
    FL
  21. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Hi Greg - Nice work!
    This is not an up-sell, but to Bill's point - it's best to send in the inner door handle assemblies, their buckets and mirror control all at the same time so that once you put this all back together, it's done for life. It's never the best idea to install freshly refinished parts into trims that will fail at some point.
  22. Graz
    Graz Formula 3
    Oct 15, 2012
    2,328
    Graziano
    Greg,
    Great job and photos! When you get the parts back from Sticky Rx (assuming you're using them) you will be amazed. Like a brand new interior.
  23. Graz
    Graz Formula 3
    Oct 15, 2012
    2,328
    Graziano
    #23 Graz, May 1, 2017
  24. Andrew D.
    Andrew D. F1 Rookie
    Jul 6, 2008
    3,979
    Goodwood Ontario
    Andrew D.
    Those door clips get brittle after 20 years. Its always good to have some extra ones around.
  25. greg246
    Jun 2, 2004
    26,599
    Yep, I'm going to try to get those out too, but looks a bit more complicated
