430 - Door handle repair | FerrariChat
430 Door handle repair
Discussion in '360/430' started by szechyjs, Oct 5, 2025 at 6:04 PM.
  1. szechyjs
    szechyjs Rookie
    3
    Ohio, USA
    Jared
    My passenger door handle stopped working properly last week. Today I removed the door card to investigate why. I suspected a bolt fell out and simply needed reinstalled. Upon getting everything removed, I found a nut, and a couple washers in the bottom of the door, this started to confirm my suspicion. I removed the door handle and confirmed the complete pin assembly that it pivots on was missing. The only problem was the pin was nowhere to be found. I went to the interwebs to locate a new/replacement pin (P/N 64860800), I was shocked to find that they cost upwards of $100. I then found some complete door handle assemblies on ebay that were approximately the same price that I could source the pin from. Then I had the idea of simply 3D printing a replacement. The factory pin is simply a stepped bolt that acts as a spacer as well. The design I came up with is simply a stepped spacer that I can put a M4 bolt through into the existing factory nut. Reassembled with a little grease and some loctite (to prevent this from happening again) and it works perfectly.
    Here is the model if anyone else needs it: https://www.printables.com/model/1434626-f430-door-pin
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    Qavion likes this.
