Door jamb switch | FerrariChat
Door jamb switch
Discussion in '308/328' started by david bentley, Jul 18, 2016.
  1. david bentley
    david bentley Karting
    Jan 2, 2004
    182
    Saint Louis Mo US
    David bentley
    #1 david bentley, Jul 18, 2016
    Both of my door jamb interior light switches failed. The insulating washer came apart and allowed the contact to come adrift. Repaired them by drilling and taping for a 3 mm screw. While there...stretch the spring and clean the contact points. Needed to fab a new insulating washer from stiff plastic. Easy job!
  2. WaltP
    WaltP Formula 3
    Nov 1, 2003
    1,512
    Cape Canaveral/Atlanta
    Walt P
    David, Is is me or does that not look quite right?
  3. david bentley
    Jan 2, 2004
    182
    Saint Louis Mo US
    David bentley
    Don't know what you mean.....I have not been quite right for years!
  4. robo330
    robo330 Formula Junior
    Apr 15, 2014
    608
    Michigan USA
    Karl Robertson
    My Doorjamb Switch gave up the ghost couple of months ago. I notice that your Switches have the Male Tab where the Female connector goes on that points in the same direction as the axis of the spring movement. My switch, when I removed it was at 90 degrees to the axis of the movement. As there is not enough room for the spring to move fore and aft, the Tab had fatigued and broke. I bent the tab on the replacement Switch to look like yours, and it works fine now. This is what WaltP may be referring to as not looking quite right...? Walt..?
  5. robo330
    Apr 15, 2014
    608
    Michigan USA
    Karl Robertson
    BTW, take care of those Switches, they are not available anymore. I was luck to get one from someone on this site. You can use a Porsche Switch but the plastic is Black instead of White for the Ferrari ones.
