door latch jammed, 512 TR | FerrariChat
Discussion in 'Technical Q&A' started by akml, Sep 2, 2006.
  1. akml
    akml Karting
    Nov 2, 2004
    84
    philadelphia
    Help!!
    The door latch got jammed closed when the door was open on my 512 TR so I can't close the door now.
    I tried but can't open the latch to close the door. Is there a trick to this??
  2. Ferrari Mackintosh
    Ferrari Mackintosh Formula Junior
    Sep 21, 2004
    716
    N/A
    Ferrari Enthiusiast
    This happened twice to myself. You have to pull the latch back with a screwdriver.
  3. akml
    akml Karting
    Nov 2, 2004
    84
    philadelphia
    I tried putting the screwdriver in different spots. No luck. Any more guidance?? Where should I put the screwdriver?
  4. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    If the latch is the same as on my 91 Testarossa.... you will see in the lower right corner ( when viewing straight on ) a hammer- like shape. It is probably in the closed position. ( No open " C " to the inside of the latch) You can pull the " hammer " down with your fingers. It almost has a little ear that you can pull down thus opening the latch.
    I hope this helps.
    Shamile Shams Kassam II
    Freeze...Miami Vice !
  5. akml
    akml Karting
    Nov 2, 2004
    84
    philadelphia
    thanks, I did it.
    I figured out I have to hold/lift the door handle to disengage the lock, before pulling the latch down.
