Door light question...That damm red light! | FerrariChat
Discussion in '308/328' started by Formula Uno, Jan 26, 2010.
  1. Formula Uno
    Formula Uno F1 Veteran
    Oct 8, 2008
    6,659
    New York City
    My passenger side door light was not working (drivers side was OK) so I removed the 2 small screws, moved the light fixture around and the light came on. So far so good I thought, but now the light stays on even when you close the door! I depressed the door button with my finger several times and it just stays on. I then removed the button and cleaned the contact points and put it back in place...now neither side door lights work!
    What could be going on here? Is the problem with the light or button? I would appreciate your advice.
    BTW I did notice that the little white plastic light-fixture/housing has 2 male contacts on it, but I only saw one wire connecting to one of them. Should there be 2 wires connecting to the 2 male contacts?? There may have been 2 attached, but possibly I dislodged one when I moved the light around. 2 or 1?
    What do you think??
    Thanks Frank
  2. FF8929
    FF8929 Formula Junior
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    The other terminal should be the dedicated ground. The wire may have broken off the connector. You may have to remove the panel to find and fix it.
  3. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    One side of the door ajar switches goes to ground. The other side of both right and left door switches is connected together from side to side and go to the 'door ajar' light on both sides. The other side of both lights goes to fuse F left box.
    Now then, lights on both sides always have voltage available and are simply awaiting a ground from either side switch. Concentrate on one door switch at a time as inadvertant shorts to ground do no harm. You will soon learn where the problems lie. Most often a bad ground or switch is the cause... switches themselves need occasional cleaning.
    If both lights fail to light with both doors open chances are the fuse isn't getting 12 volts into the doors OR both switches are bad, OR both lights are bad...unlikely.
    On some cars, you can become confused as the drivers door has two switches, the second one is for the seat belt circuit. If you have such a car (2v injected) you can easily ascertain which is the seat belt switch as it's the oddball color. I.e. the door jam light switches are the same color on both sides. Fortunately, these cars have a built-in spare switch as who needs a working seatbelt circuit?
    ________________________
    http://www.FerrariWiring.com
  4. Formula Uno
    Oct 8, 2008
    6,659
    New York City
    Thanks so much fellas...this is confusing stuff for me.
    I looked again at the plaastic light housing and it seems that the "lost" wire is taped to the other wire, which is connected to the light....could this be? I am looking at it through the hole in the door, since I have not remove the door panel. I think trying to do so will make my problems worse.
    I am still a bit confused guy's. Are you saying that each light housing should have 2 wires connecting to it? Could it be my pass side only had 1? (remember, it worked)
    Sorry that I am not being much help, but my knowlege is pretty limited here!
    I will check for blown fuse tomorrow as well.
  5. Doug
    Doug Formula 3
    Nov 13, 2003
    1,473
    Louisville KY
    Doug
    the panel that they are attached to is held on only by 2 bolts. Taking it off is about as hard as removing the floor mats.
    Also, was the driver door open while you were playing around with it. On my car the pass side light comes on when the driver door is opened and the pass side is closed.
  6. Formula Uno
    Oct 8, 2008
    6,659
    New York City
    Hey Doug,
    By the panel, I am refering to the door panel. I did remove the panel that you are talking about, and removed and cleaned the button switch.
    When I did it the driver's side door was closed.
  7. FF8929
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    The electrical schematic would be very helpful to you. They are available here. Do a search, they're free.
  8. PittsS2APilot
    PittsS2APilot Formula Junior
    Jun 29, 2007
    857
    Gulfport MS
    Joe
    I had to deal with this a couple of years ago but I don't remember what fixed it. I think I just cleaned everything? Don't you just love how something simple can be made very complicated by the Italians? :)
  9. Helmut
    Helmut Formula Junior
    Dec 11, 2004
    640
    This may not be exactly your problem here but I want to point out that the plate where the switches are mounted on, on the doorjam, is ground for the switches. In case you remove the plates and press the switches nothing will happen, as far as I recall.
    Helmut
  10. Formula Uno
    Oct 8, 2008
    6,659
    New York City
    I just want to thank those of you who responded to my post.
    Using a bit of info from all of you I fixed my lights! I'm so psyched that I was able to do it myself. I got alot of satisfaction in seeing that little red light come on.
    What was wrong....I really don't know. In short I took it all apart, cleaned everything, and put it back together again.
    Paul, the fuse was blown, so you were right that I probably shorted it out. Thanks.
    Putting the door panel back on was a pain in the ass, but I took my time and it worked out as well.
    By the way, when I removed the panel, I saw that someone wrote a big "6" on the door metal with a grease pencil.
    Who knows??
  11. Formula Uno
    Oct 8, 2008
    6,659
    New York City
    I just wanted to make sure that you guys got my thank you reply!!
    Caio!
  12. 308 GTB
    308 GTB F1 World Champ Rossa Subscribed
    Feb 7, 2002
    11,718
    New Jersey
    Barry Wolinsky
    Frank,
    The "6" you found written on the inside of the door refers to how many hours it would take for someone to do the repair you just did. ;)
    Actually, it might be the build number for your car.
    Barry
  13. Formula Uno
    Oct 8, 2008
    6,659
    New York City
    You're right about that one! Six hours and $800 later at a Ferrari dealer I bet.
    Interesting comment regarding the "6" on the door panel. When you say build number, does that mean 6th car made for that day??
  14. 308 GTB
    Feb 7, 2002
    11,718
    New Jersey
    Barry Wolinsky
    Frank,
    The build number or assembly sequence number is stamped on the coil bracket of early 308s and on the chassis element on the left side of the engine bay on later cars. These numbers appear written on the inside of the various body panels. Check your engine bay for your car's build number.
    Refer to this thread: http://www.ferrarichat.com/forum/showthread.php?t=61994
    Kare is keeping a list of assembly sequence numbers which he updates frequently: http://ferrarichat.com/forum/showthread.php?t=176780
    My 308 GTB's build number is 5A and appears on the coil bracket
    Barry
  15. Formula Uno
    Oct 8, 2008
    6,659
    New York City
    Hey Barry,
    You are going to make me go crazy now...this is interesting stuff. I will read the thread.
    My 1980 GTSI is #33553
