Door lock cylinders, what holds them in? | FerrariChat
Discussion in '456/550/575' started by cls, Sep 17, 2017.
  1. cls
    cls Formula 3
    Jun 12, 2007
    1,663
    Los Angeles/Montreal
    Chris
    My passenger door lock fell into the door while I was washing my 456GT today. The cylinder is screwed to a mounting plate and that plate was glued to the door skin. That can't be right... right? I can't figure out from the parts diagram if there is something to hold it in place, and my driver's door is the same way.
    Anyone know how the lock cylinder is held in place?
  2. cls
    cls Formula 3
    Jun 12, 2007
    1,663
    Chris
    FYI, this is what the lock cylinder looks like from the inside. No way that's factory, but I have no idea what's missing.
  3. Motob
    Motob Formula 3
    Nov 11, 2003
    2,368
    Frederick, Maryland
    Brian Brown
    The plate is supposed to be welded to the door skin, then the lock cylinder bolts to the plate. I have seen them glued back on after someone punches the door locks out when breaking into the car.
    It is a fair amount of work to have them repaired correctly.
  4. cls
    cls Formula 3
    Jun 12, 2007
    1,663
    Chris
    Thanks.
    Welding after paint doesn't sound like a good idea to me, there's also a tack welded cover plate that makes working in the area tight.
    Even with an adhesive, getting that plate in and lined up is going to be tough.
  5. cls
    cls Formula 3
    Jun 12, 2007
    1,663
    Chris
    I just stripped the plates and cleaned the inside of the door skin. These definitely were never welded. Something is missing.
