door lock gasket | FerrariChat
door lock gasket
Discussion in '206/246' started by vrooom, Aug 31, 2014.
  1. vrooom
    vrooom Formula Junior
    Jan 29, 2007
    457
    looking to replace the rubber gasket between the door lock and the painted surface of the door. any sources ? hopefully in the U.S. thanks, dan
  2. omgjon
    omgjon F1 Rookie Owner Rossa Subscribed
    Feb 13, 2005
    3,569
    Spicewood, Texas
    Jon Gunderson
    I found the best way is to buy round flat rubber washers at Home Depot. Just use an exacto knife and cut the center out to fit the lock. Fits perfect and looks original.
  3. vrooom
    Jan 29, 2007
    457
    thanks jon ,will head to home depot tomorrow . dan
  4. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    I'm helping Danny tighten his door lock.
    A question for the Dino population - Have you see Dinos with something between the door surface and the chrome ring that surrounds the door key cylinder?
    He has found one black on the opposite side but nothing on the passenger.
    I have also seen a white used.
    Thanks in advance
  5. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
