door lock keys | Page 2 | FerrariChat
door lock keys
Discussion in '348/355' started by Houston348, Feb 25, 2008.
  1. PAP 348
    Dec 10, 2005
    100,249
    Mount Isa, Australia
    Pap
    The key was given to me by a fellow Fchat member. (Thanks Dom. ;);))
    The Enzo key was a pre-cut key purchased from the Wynn Ferrari Store. :):)
    I had to open it up, remove old pre-cut key, cut a new key, then I modified it to fit. :):)
    I have some pics here on Fchat somewhere about the job. :):)
  2. Night life
    Night life F1 Veteran
    7,325
    The city that rhymes with fun in Canada
    Roberto
    Very cool thanks buddy for the info I have done similar work to my Porsche key old for new.
  3. PAP 348
    Dec 10, 2005
    100,249
    Pap
    Too easy mate. ;);)
  4. UConn Husky
    UConn Husky F1 Rookie
    4,425
    CT
    Jay
    +1, same here - and the best mod I've done!
  5. fcmotorsports
    fcmotorsports Karting
    Feb 4, 2008
    103
    Garage
    michael
    Could someone please answer my question(Post #24)???
  6. notbostrom
    notbostrom Formula Junior
    May 8, 2006
    957
    Orlando, FL
    Ben
    I have one blank OEM 348 key for sale if you can't find one anyplace else... PM me for details..
    Ben
  7. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,622
    Gates Mills, Ohio
    Jon
    Michael, the keys4classics guys don't do 355 and later - probably because the blanks are proprietary. Unless some of the 355 people chime in here, I'd suggest you call your dealer. Your profile locations says "garage", which doesn't really tell me much, so I have no idea what other options you'd have.
  8. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    Michael; I'll try to answer your question, based on my limited experience with automotive key cutting.
    It would appear that your number (K7270) probably IS a key code. The Ferrari dealer would have a reference book that converts the code number to a cutting pattern. I don't know if a regular locksmith would have access to conversion chart for every type of car. I would be VERY surprised if the guy at Ace Hardware could cut a key based on the code.
    As an example, a code of K7270 might convert to a cutting pattern of 23415, where 1 is the shallowest cut, and 5 is the deepest cut. You put the key into the cutter, move it to step 1, and cut a notch 2 cuts deep, then move to step 2 and cut a notch 3 cuts deep, etc. This is how you cut a key based on a code number.
    If you want to "re-key" the lock, you take the pins out of the tumbler. You have five pins, at depths of 2-3-4-1-5, and you just scramble them to any sequence, say 4-1-5-3-2, and then cut a new key where the first step is at a depth of 4, the second step at a depth of 1, etc.
    If you have the tumbler in your hand, and you have an uncut blank, you can either cut a key based on the code, if you have a conversion table, or you can take the pins out and cut a key based on the depths of the pins. I have done it both ways when I worked at Acura. It's easy. The dealership ordinarily keeps a list of the code numbers on all of the cars they sell, in case an emergency comes up and the owner misplaces his keys, or if the finance company needs to repo the car and the owner won't surrender the keys.
  9. fcmotorsports
    Feb 4, 2008
    103
    Garage
    michael
    Thanks Jon and Jeff......very helpful.
    Does "PIN CODE" number on that little sheet in the Owners' Documents tell the dealer how to cut a key?
  10. UConn Husky
    4,425
    CT
    Jay
    355 keys use a Fiat blank, local foreign car locksmith had blanks for a few bucks and cutting was no problem from the original.
  11. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    Hey PAP, is that a key for a Ferrari? Are u sure mate? I mean you have a Ferrari crest on the key and one on the fob. You sure u have a Ferrari there, bud? :p
  12. PAP 348
    Dec 10, 2005
    100,249
    Pap
    I still need re-assurance that I actually OWN a Ferrari. :D:D
  13. Bullfighter
    Jan 26, 2005
    22,622
    Gates Mills, Ohio
    Jon
    Good to know, thank you.
  14. dleach100
    dleach100 Rookie
    Nov 21, 2007
    2
    Atlanta
    Dana Leach
    i need to make a spare - where i can buy a blank for an '87 328
  15. Ricambi America
    Sponsor Owner
    We have them. Call us (336-499-2500) and and ask for part number 168786-R. They are $11/each.
