Door locks 1990 TR | FerrariChat
Door locks 1990 TR
Discussion in 'Boxers/TR/M' started by enoberoib, Nov 15, 2012.
  1. enoberoib
    enoberoib Rookie
    Mar 14, 2010
    26
    maryland
    robert Congedo
    Besides the fuse is there any common reason that the door locks would fail? It used to lock the passenger side with the drivers side but no more.I was wondering if there is anything relatively easy to check without taking the door apart. I remember someone had a detailed instruction how to take the door apart but I don't remember when it was. Let me know .
  2. fast eddy
    fast eddy Formula Junior
    Apr 8, 2010
    282
    Utah
    Ed Davenport
    I too have recently had this same occurance! Any help on this would be great!
  3. Red Head Seeker
    Red Head Seeker Formula 3
    2,443
    San Francisco Area
    Mark
    Due to the infrequency of use, I would venture to estimate....corroded contacts.....Mark
  4. curtisc63
    curtisc63 Formula 3
    Dec 13, 2005
    2,290
    Maryland
    Curtis Campbell
    Hi Rob,
    I think the thread you are looking for is here in the technical section on power window motors. Lots of good pics and description.
    http://www.ferrarichat.com/forum/showthread.php?t=44288
    I tend to agree with Mark - likely a bad connection somewhere. Trace wires to the solenoid and clean up all connections.
    Curtis
  5. jrbaldwin
    jrbaldwin Karting
    144
    Pacific North West
    James Baldwin
    My door locks did not work properly and the PO installed a aftermarket actuator on the drivers side. While fixing the slow windows I remove aftermarket actuator, put the wiring back to stock and cleaned the connection in both doors and the doors lock starting working.
    Jim
  6. enoberoib
    enoberoib Rookie
    Mar 14, 2010
    26
    maryland
    robert Congedo
    Thanks for the help I will check the contacts.
