Door panel material | FerrariChat
Door panel material
Discussion in '206/246' started by racerboy9, May 3, 2020.
  1. racerboy9
    racerboy9 F1 Rookie
    2,642
    The original door panel material is tempered hardboard. The metal clips chew it up easily when installing them. Has anyone used something better? I usually like to go original but might waver on this as it is unseen.
  2. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    I tried this material, easy to cut and drill etc
    https://www.lathamtimber.co.uk/products/panels/plywood/birch-plywood/thin-finnish-birch
    Once i fitted it i didnt really like how it fitted on the door, difficult to explain but it sat too straight, ie it didnt bend to suit the door, the material was too stiff. May have been better if i used something thinner than the original hardboard but went back to hardboard and much better.
    Tony
    PS- Dont forget the moisture vapour barrier, i fitted mine to the actual panel rather than the door as thats the bit you want to protect and secondly if you ever need to get inside the door to repair anything you dont have to bust through it.
  3. racerboy9
    racerboy9 F1 Rookie
    2,642
    Tony, thanks for your experience with plywood. I was thinking of going that route but I guess I will stick with the original tempered hardboard. I saw that pic of your door panel with the vapor barrier attached. Great idea and I will do the same.
  4. dgt
    dgt Formula 3
    Jan 14, 2011
    1,292
    Northeast, USA & Oz
    Andrew
    Also look at 0.118" ABS plastic sheet, I used 2'x4' white sheets of this and it's what some shops use.
    I made up cardboard templates then cut the ABS sheets and trimmed to trial fit and drilled the holes for screws and clips. Gave it to a trim shop to glue/staple the vinyl and padded backing, came out great and ABS can bend OK to fit over handles etc. Other plastics are likely too stiff, ABS seems to be the right balance.
    +1 on the vapour barrier, the doors have quite an angle on them and water drips onto the backside.
  5. racerboy9
    racerboy9 F1 Rookie
    2,642
    I see a lot of ABS 1/8"/ .0125" sheet on Ebay with free shipping. Do you think the extra .007" will make much of a difference?
  6. swift53
    swift53 F1 Veteran
    8,283
    E.S.
    Alberto
    A 'Post It' folded in half is .007".
    I think it is of no difference.
    Regards, Alberto
  7. dgt
    dgt Formula 3
    Jan 14, 2011
    1,292
    Northeast, USA & Oz
    Andrew
    #7 dgt, May 4, 2020
    Got mine from online metals, it's just what they had :)
    ...just looked again is it's been 4-5 years, part #21776
  8. swift53
    swift53 F1 Veteran
    8,283
    E.S.
    Alberto
    Is there an e-bay link? Tried, but no results
    Online M. is too expensive on the shipping, + I have 2 legs of freight.
    Regards, Alberto
  9. TTR
    TTR F1 Veteran
    5,889
    Riverside, CA
    Timo
    Alloy 5052 sheeting ?
  10. racerboy9
    racerboy9 F1 Rookie
    2,642
  11. isuk
    isuk F1 Rookie
    Nov 11, 2005
    3,330
    Iain
    The trimmer I used had worked on a lot of Dinos over the years and preferred to stay with the original factory method and use hardboard when replacing old door panels. I tracked down some waterproof plastic for the door membrane that was as close as possible to the original factory material we found on my unrestored car #04054. I can't recall where I got that material as it was 8 years ago now. To add an extra level of waterproofing the trimmer fitted some black plastic sheet to the rear of the door card.
  12. racerboy9
    racerboy9 F1 Rookie
    2,642
    I have ordered the ABS sheets so I will see how that works. I had two NOS silver door sealing plastic pieces I found in Italy with Dennis McCann decades ago but alas I can't find them now.
  13. Ken Ivey
    Ken Ivey Formula Junior
    255
    Portland, OR, USA
    Ken Ivey
    If you order new sealing pieces and then go to put them away - you'll probably find the ones you put away decades ago. Happens to me all the time :)
  14. pshoejberg
    pshoejberg Formula 3
    1,818
    Denmark
    Peter H
    #14 pshoejberg, May 5, 2020
    I used the original type hardboard and painted it with a durable two component automotive paint on the backside to establish a failsafe water barrier. Never had any issues since and I often wash my car pouring water down through the window opening. Hardboard is easy to work with and clips etc. will work fine in that material.
    The picture below is the original board from 69. Still going strong but not particular straight after years of moister and water intrusion.
    Best, Peter
  15. dgt
    dgt Formula 3
    Jan 14, 2011
    1,292
    Northeast, USA & Oz
    Andrew
    the edges have the vinyl plus 2 layers of backing rolled over and glued, then strips of edge piping are glued on top of this and the whole thing is stapled to the backing on the rear.
    You can’t staple the alloy, and it all really has to be stapled down I believe.
    I’ve replaced these panels with wood, it’s fine too but the ABS was better to work and fit (cutting with a sharp knife and bend to break).
    Also, you can mark up white panels, black not so much. It’s all hidden so white works.
  16. racerboy9
    racerboy9 F1 Rookie
    2,642
    I am going to try gluing my piping on with 3M 1357 adhesive. I've tried a lot of supposedly good contact adhesives but they have all let me down eventually except this 3M product.
  17. TTR
    TTR F1 Veteran
    5,889
    Riverside, CA
    Timo
    My soft alloy sheeting suggestion was just another among others and having (successfully) worked with, I know it being a viable option which can be stapled, riveted, etc, but if prepared properly for use with professional grade adhesives, can also be practical solution without any additional attachment hardware, especially if authenticity/originality is not a concern .
    YMMV
  18. racerboy9
    racerboy9 F1 Rookie
    2,642
    My ABS sheets have come in and looks like a good solution to me. I was worried a little that staples would split the plastic but now that I have tried it, no splits and holds great. Bought a Spot Nails air stapler and 3/8 crown with 3/16 leg stainless staples and also 1/4 leg staples all for about $110.
    dgt likes this.
  19. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
