Door panel Scuderia | FerrariChat
Door panel Scuderia
Discussion in '360/430' started by bart12, Jun 18, 2014.
  1. bart12
    bart12 Formula 3
    Nov 6, 2008
    1,711
    The River runs through it
    MD Leo
    Anybody can help me find the instructions to remove the left inner door panel of a 430 scuderia? Can find it in the search option.
    There is something rolling inside it when turn to the left or right while driving and I think its inside the door. Probably a loose screw or bolt.
  2. F430addict
    F430addict F1 Rookie
    Sep 17, 2010
    4,460
    Sure its inside the door and not under the floor pan? Reason I'm asking is coz I had the same issue when the mechanic replaced the fire extinguisher mounts, he drilled out the rivets and some fell through. Didn't bother to try and get those out, obviously coz that'd involve removing the entire floorpan. I lived with that rattling noise for 6 months and decided to make him fix the issue. Finally no more rattles. Only rattling now comes from my teeth.
  3. bart12
    bart12 Formula 3
    Nov 6, 2008
    1,711
    MD Leo
    I am 80% sure. I can somewhat reproduce it when swinging the doors but really it is really only when driving/turning the car.
  4. F430addict
    Sep 17, 2010
    4,460
    There are few visible bolts that hold the panel plus removing the pull lever. The panel should fall straight off. I did it once. It was that simple.
    Sent from my SM-N9005 using Tapatalk
  5. bart12
    bart12 Formula 3
    Nov 6, 2008
    1,711
    MD Leo
    I am sure there is an object rolling inside the my driver side door and I tried removing the CF panel but having difficulty. I removed the bolts and tried pulling the door but it won't budge.
    I am doing it right? Any suggestions as to what I am doing wrong?
