Door pocket repair | FerrariChat
Door pocket repair
Discussion in '308/328' started by CDBELL, Jun 15, 2021.
  1. CDBELL
    CDBELL Rookie
    Dec 30, 2020
    30
    Chance Bell
    Hello All,
    It appears the springs holding the door pocket in place on my 328 has given out. I was able to locate a place that sells replacement springs but do not have a clue how to disassemble and replace the springs. Anyone know of a video or link on instructions? Or can explain how to remove the pocket to get access to the springs?
    Thanks,
    Chance
  2. Talon38
    Talon38 Karting
    142
    Austin, Texas
    Mike Lambert
    Chance,
    I'm in the process of putting my car back together, so could get some photos for you. Unfortunately, you have to remove the inner door to get to the springs. The pocket is bolted through the inner door. I've taken some photos to show you what the pocket looks like on the inside and what the springs should look like when you are done. I found that the "body" of the pocket at the springs had come apart and the area of the screws that hold the spring assembly on had broken down, but got some JB Weld and filled the space. After it set, I predrilled the holes and put it back together. So far, so good. It's a bit interesting to get the springs on correctly. Hope these help! Mike
  3. Cennzo
    Cennzo Karting
    Jan 29, 2020
    111
    Sausalito CA
    Vince Dattoli
    Yikes. Thanks for posting. I was interested because I have the same issue, but I think I'll wait till the next pandemic to tackle that repair!
  4. Talon38
    Talon38 Karting
    142
    Austin, Texas
    Mike Lambert
    Not a bad plan. 100 years or more (I hope)....
  5. CDBELL
    CDBELL Rookie
    Dec 30, 2020
    30
    Chance Bell
    Thanks Mike, good to know. Looks like a bit more involved that I want to do this week. Ha!
  6. Kent Dellenbusch
    Kent Dellenbusch Formula Junior
    664
    Upland, CA
    Kent Dellenbusch
    Thanks Mike. Good photos.
  7. jdjagguy
    jdjagguy Karting
    Sep 11, 2007
    76
    Enid Oklahoma
    Richard Crump
    I have "repaired" these springs by taking two, needle nose pliers and unwinding a coil of the spring at the break. (I have only had them break at the end of the coil). Richard C
    Kent Dellenbusch likes this.
  8. Kent Dellenbusch
    664
    Upland, CA
    Kent Dellenbusch
    Thank you Richard.
  9. craiggo
    craiggo Formula Junior
    416
    Redwood City
    Craig
    Did you get the info you need to repair these? I’m doing mine now and have detailed photos I can upload.
    Craig
  10. Kent Dellenbusch
    664
    Upland, CA
    Kent Dellenbusch
    #10 Kent Dellenbusch, Jun 10, 2022
    I'd love to see how it's done. Can the pocket assembly be removed without removing the whole inner door skin? Just removing a few of the bottom screws to get a wrench in to remove the few screws that attach it to the door skin?
  11. craiggo
    416
    Redwood City
    Craig
    Kent,
    I'm back home and found the pictures you need. Unfortunately, I don't see how you can replace these springs without taking the door panel off. It's a one-beer job. Not more than 30min at least in my case ('87 328 with the hidden door handles). Door panel comes off then the armrest attachment comes off. Flip it over and that's what you see here.
    I've uploaded the pics I took to document my work (ok, remind me how to reassemble). Let me know if you need any other photos as I have everything disassembled now.
    Craig
  12. Kent Dellenbusch
    664
    Upland, CA
    Kent Dellenbusch
    Thank you Craig,
    This is very helpful. I see how you un-wound one end of the coil-spring and looped it through the hole. I'll look for inner door skin removal next.
  13. craiggo
    416
    Redwood City
    Craig
    Kent,
    I didn't do that, it was like that when I pulled it apart. I noticed it wound also and couldn't figure out why it was like that but it must have been previously repaired.
    I am going to go check now.
    Craig
  14. Kent Dellenbusch
    664
    Upland, CA
    Kent Dellenbusch
    It works for me. It looks like it will do the trick.
