Door seal help needed. | FerrariChat
Discussion in '308/328' started by TommyA, Nov 13, 2021.
  1. TommyA
    TommyA Formula Junior
    Oct 7, 2002
    549
    Atlanta
    Tommy A
    There's a seal on the front of the window frame that meets with the A pillar of the vehicle when the door is closed. The seal has a channel.. does it face the outside or interior of the vehicle?
  2. Du_Man
    Du_Man Formula Junior
    320
    Dallas, Texas
    Derek
    Does this photo help? Orientation looks to be the same as you have it. I have my doors fully disassembled but have not removed this seal just yet.
  3. TommyA
    Oct 7, 2002
    549
    Atlanta
    Tommy A
  4. TommyA
    Oct 7, 2002
    549
    Atlanta
    Tommy A
    Derek did you remove the small glass while the frame was in the car or you removed the complete assembly all together?
  5. rjlloyd
    rjlloyd Formula Junior
    Jun 19, 2014
    447
    Brisbane, Australia
    Richard Lloyd
    Image Unavailable, Please Login seal faces outwards. I don’t think you’d be able to remove the quarter glass with the frame in the door, and I’d be confident to say you’d never get it back in the frame fitted to door, it was a real pain in the proverbial to refit the glass to the frames
    Du_Man likes this.
  6. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
  7. Du_Man
    320
    Dallas, Texas
    Derek
    I removed every piece and part from the doors. Everything needs repainting and every seal needs to be replaced and window motors need attention. Small glass was separated from the seals after removing from the door. All glass cleaned, wrapped, and put away for safe keeping. Gonna be quite the process!
  8. TommyA
    Oct 7, 2002
    549
    Atlanta
    Tommy A
    I have powder coated mine and they came out really good. Used Columbia supper matt black powder.
  9. Du_Man
    320
    Dallas, Texas
    Derek
    Excellent info......the Columbia super matt black powder has a light sheen gloss that matches the rest of the trim?
  10. TommyA
    Oct 7, 2002
    549
    Atlanta
    Tommy A
    Yes it does. It looks fantastic! I couldn't be happier. As a matter of fact I did the rear louvers as well.
    Du_Man likes this.
  11. TommyA
    Oct 7, 2002
    549
    Atlanta
    Tommy A
    Derek there is a black o ring plastic seal by the lock cylinder. Is it on the outside of the door or inside? Thanks
  12. Du_Man
    320
    Dallas, Texas
    Derek
  13. rjlloyd
    Jun 19, 2014
    447
    Brisbane, Australia
    Richard Lloyd
    Image Unavailable, Please Login .
    There’s a black plastic gasket that goes between the barrel and the door skin if that’s the one you’re referring to.
    Du_Man likes this.
  14. TommyA
    Oct 7, 2002
    549
    Atlanta
    Tommy A
    That's the one. Thank you. It's been some time since I removed them and could not remember.
  15. TommyA
    Oct 7, 2002
    549
    Atlanta
    Tommy A
    On the GTS is there window stop on top and bottom? If so can someone please post some images?
  16. Du_Man
    320
    Dallas, Texas
    Derek
    Tommy, sent you a link to download my notability PDF (my door disassembly write-up).....maybe the answer is in there!
  17. TommyA
    Oct 7, 2002
    549
    Atlanta
    Tommy A
    Derek thank you so much!! Lot's of useful info. I have been doing exactly what you are doing. If you replace the motor cable, Birdman documented that the length of the cable is 10' 10". I did this on one side and things were extremely tight. I did the other side 1" longer and that really helped.
  18. Du_Man
    320
    Dallas, Texas
    Derek
    Excellent - I got new cable wire from amazon ready to go!
  19. 4rePhill
    4rePhill F1 Veteran
    Oct 18, 2009
    8,254
    Worcester, England
    Phill J
    Years ago I had to replace the window cables in my FIAT X1/9.
    The cable part was no longer available from FIAT, but a bit of lateral thinking had me heading to my local bicycle repair shop for a large coil of bicycle brake cable (I actually bought their entire stock of cable! :D)
    I had to create my own crimp pieces for the ends of the cable, and once done, the cable worked perfectly! :)
    BigTex and Du_Man like this.
