Door seals 355 | FerrariChat
Door seals 355
Discussion in '348/355' started by wlracing, Dec 23, 2004.
  1. wlracing
    wlracing Karting
    Dec 14, 2004
    234
    wally
    I have been told of a trick to put a small plastic tube up inside the rubber door seal to help it keep shape so preventing leaks ,has anyone tried it & does it work ?
    Wally.
  2. f355b
    f355b Formula Junior
    Jan 23, 2004
    449
    Little Silver,NJ
    I did it on my old TVR work great, not 100% sure what they used.
  3. 355flyer
    355flyer Formula Junior
    Nov 1, 2004
    338
    Gadsden, Alabama
    Andy Entrekin
    Is it leaking around the back side near the top?
  4. absolut
    absolut Karting
    Oct 21, 2004
    61
    please kindly elaborate... i have leaking problems on my 355 GTS too.... when it pours, the junction at the front of the window where it meets the front corner of the targa top....
    it leaks a few drops here and there...
    anyone have pics or a solution that sovles this problem
    thanx
  5. wlracing
    wlracing Karting
    Dec 14, 2004
    234
    wally
    Have not collected car from dealer yet as prep work not finished before endless UK holiday should be ready early Jan.Have been told they all leak & intend to make mine the exception !
  6. Robertb
    Robertb Formula 3
    Nov 19, 2003
    1,331
    South Oxfordshire, U
    Robert
    Keeping mine garaged with the windows down and rubbing rubber-care gel into the seals has certainly improved things, but the odd little drop still get in from time to time in heavy rain on the move.
    If you really want to make the roof seal absolutely tight I'd suggest taking your car to a convertible roof specialist who will make sure that the adjustment is spot on.
    But I quote from the 355 manual "...the sealing...cannot be guaranteed in all utilzation conditions. It's clear that small infiltrations in some areas can be considered normal."
    Wally, I see your car has not been delivered yet- when it is, and you hear 'that howl' a few times, you won't care about the odd little leak...!
    Robert.
  7. wlracing
    wlracing Karting
    Dec 14, 2004
    234
    wally
    Maybe it is just another mistake in the manual !
    Wally
