Door sills revisited | FerrariChat
Discussion in '348/355' started by ferraridriver, Apr 27, 2008.
  1. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    #1 ferraridriver, Apr 27, 2008
    Here are a couple of pics of the brushed stainless inserts I finally got installed.
    First I removed the sills and had them powder coated in what they call a hammertone finish, kinda like a wrinkle finish but not as rough.
    I ordered them without tape because by themselves they are thick enough to fill the depression left when the rubber insert is removed.
    I installed them with caulking adhesive so they fit flush now.
    I had ordered both brushed and mirror finished, found I like the brushed finish better plus it hopefully won’t show scuffs as much.
    Anyone who wants my extra set of mirror finish for $100 PM me, or I’ll just keep them for spares.
    I got them from Jaime at http://www.carztuff.com/ and I have to say they are first quality work.
  2. pyroguy
    pyroguy Formula Junior
    Dec 20, 2006
    669
    Minnesota
    Steve
    Dave,
    I'm also looking to powdercoat my door sills. Many have said they are difficult to remove without bending them beyond recognition since they are glued down. What process did you use to remove them? I was thinking a heat gun to help soften the glue.
    Would appreciate any tips you have.
    Steve
  3. ferraridriver
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    It ain't easy, took about a half hour for each, the first one was a problem because I didn't know about the screw under the rubber mat, but once I knew how, the second one came off perfectly flat.
    Use a 10 inch long, one inch wide, thin cake spatula, tap it in with a hammer and lever it back and forth sideways. Just keep doing it as you work along the sill.
    You might try lubricating it with water, I didn’t, but that might help.
    It’s vital that you never pry upwards, only sideways.
    You can put something as big around as a pencil under the sill as you work along to help, but don’t lift up much more that that.
    There are three screws under the weather stripping, and one under the rubber mat about two inches from the rear edge, peel back the rubber mat and you will see it.
    You don’t have to remove the door weather-stripping, just lift it up to locate the screws.
    There is one little dab of rubber glue at the very forward most corner of the sill.
    Hope this helps.
    Dave
  4. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,973
    MD and NE
    Robbie
    Looks nice!! Great tips Dave, bravo!!!!!
  5. pyroguy
    Dec 20, 2006
    669
    Minnesota
    Steve
    Great Dave! It's nice to see someone else take the plunge first. I do have a friend who is in auto body work. He recommended a vibrating blade device used by glass installers. Looks sorta like a Saws all device. The spatula thing with maybe some goo gone or a heat gun might speed up the process. I'll let you know if I try it.
    Steve
  6. ferraridriver
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    Steve, I wouldn't try any kind of saw, the bonding material they used is a grey rubber like material, probably a silicon caulking compound. Goo Gone or heat should have no effect on it. It was still very flexible when I got the parts separated.
    The cake spatula really worked very well on the second one after I got the hang of it, you need one long enough to reach all the way to the threshold.
    I'd guess I could do one sill in 15-20 minutes now.
    When you get the sill off just use a razor blade to scrape off the remaining silicon from the car and the sill.
  7. pyroguy
    Dec 20, 2006
    669
    Minnesota
    Steve
    Thanks,
    I was just referring to a saws all as a reference. The unit is actually a long vibrating knife blade, no teeth. The spatula sounds like it worked for you so I'll give it a go.
    Steve
  8. fxdwgs
    fxdwgs Formula 3
    Aug 22, 2006
    1,016
    Sjobo, Sweden
    Bengt
    My door sills are also going to other hunting grounds. My problem is.........the screws under the weather seals are so rusty you can not get a screw driver in the "X" . What to do???? Grind them down and then drill them out, or just leave them where they are and drill new holes????
    My sills are covered with some plastic paint. Is that common or have they been refurbished before?
    //B//
  9. 285ferrari
    Sponsor
    Sep 11, 2004
    20,973
    MD and NE
    Robbie
    I would carefully drill the old screws out....
  10. ferraridriver
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    The paint is normal, I wiped mine down with MEK which had no effect on the paint.
    As for the screws, try tapping on the screwdriver lightly with a hammer as you are turning, and be sure its the right size screwdriver.
  11. billyfitness
    billyfitness Formula Junior
    Feb 14, 2006
    581
    Overland Park, KS
    Bill Leavitt
    Man, I like the black floor carpets against the tan carpet...nice! Good idea.
    -Billy
  12. blacksc
    blacksc Karting
    Feb 11, 2008
    69
    Vancouver, BC
    Jamie
    wow those really do look great! Do you mind if i use the picture on my website?
  13. ferraridriver
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    Be my guest, fortunately for you I’m retired and don’t need the royalties ;)
