430 - door speaker not working | FerrariChat
430 door speaker not working
Discussion in '360/430' started by Purch23, Apr 28, 2025 at 11:10 AM.
  1. Purch23
    Purch23 Karting
    Jul 2, 2019
    108
    CT
    Dave
    Hello, 2007 F430 spider. The driver door speaker and tweeter both started to not work intermittently. I noticed they would work again when taking right hand turns then go out again when the car straightened out of the turn. Now they do not work at all. I took the door apart hoping for a loose connector but all seems good. I disconnected the passenger door tweet and the driver tweet does work in the passenger connector so the speakers are working just not getting the signal.
    I'm not sure what to check next. Any suggestions?
    Thanks,
    Dave
  2. SoftwareDrone
    SoftwareDrone F1 Veteran
    Sponsor Owner Rossa Subscribed
    Jan 19, 2004
    7,789
    San Jose, California
    Does your car have the factory hi-fi option? That is, does the car have the little speaker box behind the seats and the small booster hanging under the center of the dash?
  3. Purch23
    Purch23 Karting
    Jul 2, 2019
    108
    CT
    Dave
  4. SoftwareDrone
    Jan 19, 2004
    7,789
    I sent you a PM.
    Purch23 likes this.
  5. GogglesPisano
    GogglesPisano F1 Rookie
    2,956
    East Bay, California
    Joe
    Mine does the same thing with the Bose setup. Is this an amp problem, Mike?
  6. SoftwareDrone
    Jan 19, 2004
    7,789
    Most likely. I receive many, many calls of this nature. Entire channels go out, transistors/capacitors blow, resulting in crackling and popping noises, etc. You can get the factory booster rebuilt, but in the end you still have a 60 Watt booster with an incredible (from Ferrari's own documentation) 10 percent distortion. The audible threshold for distortion is 1 percent. And a new one is over $1600.00.
    Here is a 420 Watt, 0.3 percent (inaudible) distortion, plug and play alternative solution: https://scuderiaaudio.com/product/360-430-super-amplifier/
    GogglesPisano and flash32 like this.
