Door Squeek in 328 | FerrariChat
Door Squeek in 328
Discussion in 'Technical Q&A' started by donald, Apr 27, 2005.
  1. donald
    donald Karting
    Aug 11, 2004
    197
    Dallas, Texas
    Don
    My 328 gets a squeek in the driver's door every few months. When I use a bit of WD-40 it goes away temporarily. Any better ways to deal with this? I tried a search with no luck.
  2. Fred2
    Fred2 F1 World Champ
    18,192
    nj
    The door hinges have grease fittings, and it helps to put a little grease on the bar that stops it from opening too far.
  3. f355spider
    f355spider F1 World Champ
    18,045
    I have used "super lube" teflon grease by Permatex on the latch. Use regular grease on the grease fittings on the hinges. A tad bit more super lube on the check strap.
    Do that and you will be good for a long time.
    Oh, and treat the door seals with BMW gummifledge.
