double clutching Dino 246?? | FerrariChat
Discussion in '206/246' started by raywong, Sep 15, 2004.
  1. raywong
    raywong Formula Junior
    Aug 29, 2004
    667
    Hong Kong
    Raymond
    Do Dino come with syncromesh in the gearbox? Is it necessary to double clutch when shifting down?
  2. El Wayne
    El Wayne F1 World Champ
    Staff Member Lifetime Rossa Owner
    Aug 1, 2002
    18,043
    San Marino, CA
    L. Wayne Ausbrooks
    Yes, all synchromesh. No need to double clutch.
  3. greg246
    greg246 Two Time F1 World Champ
    Jun 2, 2004
    25,692
    Sydney,Australia
    Greg
    Syncro tends to be pretty weak though, particularly changing down to 2nd. I double declutch my dino and boxer. I believe it prolongs gearbox life
  4. dm_n_stuff
    Warmed up, not a huge problem, but 2nd gear can often be tough.
    Especially when cold. My gearbox steadfastly refuses to downshift into second for about the 1st 20 minutes of driving, until the gearbox is nice and warm. Also is very touchy on 2nd gear upshift when cold, but can be done, with care.
  5. jsa330
    jsa330 F1 Veteran
    9,881
    75225
    Scott
    It's not the same car, but my 330 2+2 takes at least 15 minutes, even in summer, to get up to where everything
    is working smoothly. Water has to be at 190F and oil temp needle straight up. The first mechanic who worked on the car told me to go from first to third until warm and advised against double clutching, especially down to second. The synchros are very smooth and the engine is almost undetectable at 800 RPM idle once the temps are up.
  6. Ney
    Ney F1 Veteran
    6,663
    Ray:
    Why not double clutch down? It is good practice for any car, syncro or not. Properly done it is no slower, and the additional wear on the master in not worth worrying about. Replacement of the master cyl. is far easier than rebuilding the gearbox. Learn it once...do it for all cars.
  7. racerboy9
    racerboy9 F1 Rookie
    2,523
    I thought learning to match revs was the best way to shift. You don't even use the clutch pedal.
