Double Diffusers to be banned | FerrariChat
Discussion in 'F1' started by vinuneuro, Jan 7, 2010.
  1. vinuneuro
    vinuneuro F1 Rookie
    May 6, 2007
    2,574
    Chicago
    Vig
  2. Anthony_Ferrari
    Anthony_Ferrari Formula 3
    Nov 3, 2003
    2,365
    Sheffield, UK
    Anthony Currie
    They should get Ross Brawn to word the ruling as he was the one to spot the ambiguity in the original ruling.
    I don't believe the Diffuser had much effect on overtaking. They should use steel brakes to increase stopping distances.
  3. Prova85
    Prova85 Formula 3
    Nov 13, 2003
    1,996
    So. Shore MA.
    Kenny K
    So let's see...the FIA ruled dd's are legal in '09 forcing the teams that didn't have them to spend millions to adapt their cars to be competitive.
    Now the FIA wants to ban them for '11 and force ALL the teams spend even more millions to re-design cars without them(again).
    And all the while everybody screams that F1 is too costly and they must cut costs to be sustainable. Well WTF with rules changing so often like they do it's no wonder it's too costly. I don't want to hear all this F1 is too costly crap when the FIA continually force teams to spend huge sums to accommodate the continually changing rules.
    There is no other sporting entity on the planet that changes its rules or scoring as often as F1. No surprise they lost 3 major players this year.
  4. william
    william Two Time F1 World Champ Silver Subscribed
    Jun 3, 2006
    27,745
    Of course it was significant!!
    It gave Brawn an immense aerodynamic advantage at the start of the season and allowed Button to romp away from the field in the early races.
    Once other team adopted it, Brawn's superiority dissappeared almost overnight.
  5. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    Err, if you read the article you'd see it's not the FIA proposing this change but rather the teams themselves (via the FOTA TWG)..... Once they've agreed on the wording (I agree, let RB do it;)) *then* their proposal goes to the FIA for ratification and the rule change(s).
    Don't get me wrong, I'm no fan of the FIA (although I have higher hopes with JT) but this approach sounds good to me - It's what the teams want (regardless of cost it seems) rather than the nonsense drivel we got from Mad Max.....
    Cheers,
    Ian
  6. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,737
    But the only way to actually cut the costs by any substantial amount is to ban aerodynamics (all of it: wings, diffusers, winglettes, barge boards, wheel caps, maybe even brake ducts...)
  7. kraftwerk
    kraftwerk Two Time F1 World Champ
    May 12, 2007
    26,826
    England North West
    Steve
    +1 Correct.
  8. vinuneuro
    vinuneuro F1 Rookie
    May 6, 2007
    2,574
    Chicago
    Vig
    Significant yes, but Brawn, Williams and Toyota were not a 1sec faster. I'm wondering which cars they're comparing in which points in the season.
  9. Cartist
    Cartist Formula Junior
    Mar 28, 2006
    442
    Grapevine, TX
    Omar
    I suspect it has more to do with the turbulence the double-diffusors cause and thus, the lack of over-taking. It was easier to make the diffusors legal for the rest of '09 and '10 rather than have team protest the Brawn victories and most teams had begun work on the 2010 cars by then anyway (read: Ferrari)
  10. mousecatcher
    mousecatcher Formula 3
    Dec 18, 2007
    2,116
    san mateo, ca
    That won't really do the trick. The main reason for the carbon brakes is weight savings.
  11. Far Out
    Far Out F1 Veteran
    Feb 18, 2007
    9,768
    Stuttgart, Germany
    Florian
    +1
    Tires are the limiting factor, not the brakes.
  12. beast
    beast F1 World Champ
    May 31, 2003
    11,479
    Lewisville, TX
    Rob Guess
    Just use the following rule.
    The floor of the car must be flat from the center of the front axle to the end of the rear crash structure. No holes are allowed in the floor of the car and during inspection the front ride height must be the same as the rear ride height. No curvature and undulations allowed on the floor structure.
  13. VIZSLA
    VIZSLA Four Time F1 World Champ Owner
    Jan 11, 2008
    41,692
    Sarasota
    David
    Still trying to apply logic to F1?
  14. bigodino
    bigodino F1 World Champ Silver Subscribed
    13,159
    The Netherlands
    Peter den Biggelaar
    The 1 sec in the article was related to removing the diffuser effect completely.
  15. vinuneuro
    vinuneuro F1 Rookie
    May 6, 2007
    2,574
    Chicago
    Vig
    Removing the diffuser entirely would be much much much more than 1sec. It's pretty clearly worded, the double-diffuser design is worth 1s over conventional.
  16. bigodino
    13,159
    The Netherlands
    Peter den Biggelaar
    I thought the article mentioned a completely flat bottom. Reading back, it seems there's still room for some sort of diffuser effect. I hope they'll word it correctly! ;)
  17. 4rePhill
    4rePhill F1 Veteran
    Oct 18, 2009
    8,266
    Worcester, England
    Phill J
    Surely the main reason for the carbon brakes being used is their resistance to fading during repeated high speed use. Whilst steel brakes can pretty much match the stopping power of carbon brakes these days, they still fall short in commparison when it comes to fade resistance. The weight saving is simply an added bonus.
    Whilst this is true for ultimate stopping ability, if the brakes fade and are no longer on the verge of stopping the rotation of the wheel (where braking ability is at it's maximum), then the tyre grip on the track becomes almost irelevant as the wheel will keep rotating and the tyres resistance is reduced. Put it this way, if the brakes were to fade completely and there was no braking at all, how much would the tyre grip help slow the car?, it would be negligable.
    As for the double diffuser being banned, I don't think it should have been declared legal in the first place. The original rule was for a single diffuser with a maximum height of 100mm. I'm sure the FIA only allowed it because they knew it would cause a massive mix up in the pecking order and generate interest in the sport.
  18. VIZSLA
    Jan 11, 2008
    41,692
    Sarasota
    David
    There has always been a struggle between designers and rule makers. Every time the cars become "too fast" the rules are changed then the designers find ways to make them faster and the rule makers slow them down again ad infinitum. The particular rules and designs don't matter in the long run.
  19. 4rePhill
    4rePhill F1 Veteran
    Oct 18, 2009
    8,266
    Worcester, England
    Phill J
    It's always amazing how quickly the designers manage to recoupe any performance lost due to new rules. Those guys really earn every penny they get paid.
  20. racerx3317
    racerx3317 F1 Veteran
    Oct 17, 2004
    5,701
    New York, NY
    Luis
    What they should do is get rid of the flat bottom car altogether and allow ground effects. That way they can go back to normal sized wings, with less elements. Also ban those engine cover fins, barge boards, flip ups, etc. I hear that this was what the FIA was going to do at one time but instead we ended up with butt ugly F1 cars that still can't pass each other.
  21. mousecatcher
    Dec 18, 2007
    2,116
    san mateo, ca
    ground effects will make passing even harder! regardless of the change in other aero elements. ground effects add downforce essentially "for free", ie without a drag penalty. that will shorten braking distances.
  22. racerx3317
    Oct 17, 2004
    5,701
    New York, NY
    Luis
    If you've ever seen a GP2 race you'll notice that they have no trouble passing, and they are ground effects cars. Same for Indycars. The cars are more inherently stable. Easier to pass, not harder.
  23. mousecatcher
    Dec 18, 2007
    2,116
    san mateo, ca
    but generate much less downforce than an F1 car, and so they have longer braking zones.
  24. racerx3317
    Oct 17, 2004
    5,701
    New York, NY
    Luis
    Yes they do, which would also promote passing, don't you think?
  25. mousecatcher
    Dec 18, 2007
    2,116
    san mateo, ca
    absolutely ... in a GP2 car. put ground effects on an F1 car and you are going to go from parades to lapping demonstrations.
