Dowty Washer Sources | FerrariChat
Discussion in 'Technical Q&A' started by lkstaack, Apr 25, 2021.
  1. lkstaack
    lkstaack Formula Junior
    Dec 9, 2020
    252
    San Diego
    Lars
    I'm surprised that no one seems to carry the dowty crush washers used for the transmission coolant lines on a 360. A pair of dowty washers are used for each banjo bolt and they should be replaced when replacing the heat exchanger. While it doesn't seem that Ferrari shops carry them, I see that they are readily available on e-bay and Amazon. However, I'm sceptical of the quality of those items. Can someone refer me to an online source of quality dowty washers?
    For those wondering, I was recently educated that dowty washers have bonded rubber/plastic on the inner diameter of crush washers. They are commonly used for high-pressure hydraulics. I'm uncertain of the exact size I need, but I measured the diameter of a transmission banjo bolt at 16mm. So, I guess I need eight M16 dowty washers, right?
  2. wmuno
    wmuno Formula Junior
    515
    Wilmette, Illinois
    Bill Muno
    A fiber washer is a fiber washer. The kit on Amazon will work. Put a light coating of grease on the washer before using it.
  3. vincep99
    vincep99 Formula 3
    Jun 8, 2009
    1,938
    Sorry to disagree,m but I would not use a fiber washer. The purpose of the steel washer with rubber insert is that the steel limits the amount of crush that the rubber sees, so you get the correct axial sealing force.
    Do your search for a USIT seal ring; you can get them in all sizes from Grainger for instance; I think Parker also has them
  4. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,153
    CT
    John Kreskovsky
  5. lkstaack
    Dec 9, 2020
    252
    San Diego
    Lars
  6. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,203
    Georgia
    Wade Williams
    The trans cooler line washers can be reused without issue as well.
    brian.s likes this.
  7. lkstaack
    Dec 9, 2020
    252
    San Diego
    Lars
    My 360 parts manual shows the same dowty-style sealed washer for both ends of both trans cooler lines. I disconnected one cooler line to the transmission and discovered non-sealed washers. Is this typical? Would you be surprised if I found a non-sealed washers on the heat exchanger side? Can sealed washers be safely reused? Should the washers be annealed before reusing?
  8. Ferrari Tech
    Mar 5, 2010
    1,203
    Georgia
    Wade Williams
    I have at times used copper on the cooler lines without issue. I always use new copper washers. I never anneal them and try again. They are cheap. I also keep them in stock so it is just faster to get a new one. The original ones are aluminum with the inner seal and those can be reused.
    lkstaack likes this.
  9. afwrench
    afwrench Formula Junior
    Nov 24, 2004
    593
    NY
    Anyone know the size of the oil drain washers for a 599?
