drain antifreeze from block | FerrariChat
Discussion in '308/328' started by F&M racing, Nov 23, 2007.
  1. F&M racing
    F&M racing Formula Junior
    Feb 26, 2006
    668
    Michigan
    JimF
    #1 F&M racing, Nov 23, 2007
    I'd like to drain the antifreeze from the engine block, it appears there is a radiator like drain screw on the right rear (Pass.side) see attached picture yellow arrow. Is this the only one?
    Jim
  2. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Jim,
    That's the only one i saw when i drained mine.
    What you should do, is in the front access panel there is a small rubber line that runs into the aluminum pipe, go get one of those Antifreeze package deal things and there should be a "T" in there.
    You cut the rubber one, make sure you have a 5gl bucket to catch the big gush of antifreeze, and place the "T" in between. You now have a drain plug for next time.:)
    BTW When you unscrew the one on the block it will make a big mess cause it falls on the exhaust and all over the place. Be prepared, cause there will be alot in there.
    Good luck.
  3. F&M racing
    Feb 26, 2006
    668
    Michigan
    JimF
    Thanks Chris,
    I already removed that hose under the front access panel, I'm going to change all the coolant hoses. Need to drain the block now, last owner put near 100% antifreeze in the system, car is sitting all winter in a cold garage. I should of checked the antifreeze last winter but I didn't get a chance I figured no one puts near 100% antifreeze in a car but they did. I did run a heater in the garage a few weeks when it got real cool, hopefully everything is ok.
    Jim
  4. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    TIP:
    In addition to Chris's tips, you should:
    1)After it's drained awhile, remove the coolant reservoir cap
    2)Remove the thermostat bleed bolt (or just loosen it if you've got one of my EZBleed bolts).
  5. chairpilot
    chairpilot Formula 3
    Mar 3, 2007
    1,547
    LA, CA & Olympia, WA
    PlateClipGuys
    How much are your ez bleed bolts Verell (saw your 11/07 post reply on coolants)?
    Do you have a picture of one?
  6. Herman Ronald
    Herman Ronald Karting
    Feb 23, 2014
    197
    Netherlands, Frl
    Ronald
    #6 Herman Ronald, Oct 18, 2015
  7. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,833
    Cerritos, CA.
    #7 miketuason, Oct 18, 2015
    Drain it from the heater hose located on the bottom front under by the battery tray. It's the one connected to one of the main coolant pipe, it's about 3/4" or 19mm. This is also one of the lowest part of the cooling system.
  8. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    You're looking in the wrong place.
  9. Herman Ronald
    Feb 23, 2014
    197
    Netherlands, Frl
    Ronald
    #9 Herman Ronald, Oct 18, 2015
    Thanks, i did that already, after the pipes/radiator draining i did the block draining, i found it, it was the upper bolt (no drainingplug)
  10. Herman Ronald
    Feb 23, 2014
    197
    Netherlands, Frl
    Ronald
    another 2 gallons coolant out of the engineblock!
  11. Ehamilton
    Ehamilton F1 Rookie
    2,768
    Durham, NC; USA
    Eric Hamilton
    The local chain FLAPS will have a funnel with a long neck, just right to wdge up against the block under the drain fitting. Stick an old length of heater hose over the neck, you can drain it right into any convenient container.
  12. SeattleM5
    SeattleM5 Formula 3
    1,266
    Kirkland, Washington
    Ettore Palazzo
    #12 SeattleM5, Oct 19, 2015
    I used to go this route when draining the block on my 328 but even with the long narrow funnel I found it to be a messy affair. I got sick of the mess and modified the existing drain plug by putting a petcock drain through it. Now draining the block is super simple.
  13. i-velocita
    i-velocita F1 Rookie
    2,520
    Colorado
    James
    Thats pretty slick!
  14. Ehamilton
    Ehamilton F1 Rookie
    2,768
    Durham, NC; USA
    Eric Hamilton
    Even better! I like.
  15. SeattleM5
    SeattleM5 Formula 3
    1,266
    Ettore Palazzo
    #15 SeattleM5, Oct 20, 2015
  16. Herman Ronald
    Feb 23, 2014
    197
    Netherlands, Frl
    Ronald
    If Enzo could speak, he was speechless. ...he had a tear of joy.
    molto bene
  17. Herman Ronald
    Feb 23, 2014
    197
    Netherlands, Frl
    Ronald
    molto bene
  18. kurtbob
    kurtbob Karting
    Jun 2, 2013
    64
    Augusta, GA
    Kurt
    Could you please tell me the size or a part number for the petcock?
  19. SeattleM5
    SeattleM5 Formula 3
    1,266
    Ettore Palazzo
    My apologies Kurt, off the top of my head I can't remember what brand/size of petcock I used. My notes are all down at my Dad's machine shop where I performed the 'surgery.' If there's any interest from the Fchat community I can see what it would take to get some more of these made up. I think the biggest challenge might be getting spare drain plugs. I remember at the time I tried to purchase two from Ricambi in the event that I messed up but only one was available for purchase.
  20. Skippr1999
    Skippr1999 F1 Rookie
    4,570
    I'd be interested for sure.
  21. ZOOOOMZ
    ZOOOOMZ Karting
    Aug 14, 2013
    248
    Austin, Texas, USA
    Tim Cronin
    The inline petcock is included with the Dave Helms hose kit, if you are replacing your hoses.
  22. ZOOOOMZ
    ZOOOOMZ Karting
    Aug 14, 2013
    248
    Austin, Texas, USA
    Tim Cronin
