Drain over filled oil? | FerrariChat
Discussion in '360/430' started by Roadking80134, Jul 18, 2014.
  1. Roadking80134
    Roadking80134 Formula Junior
    Dec 5, 2013
    267
    Spring, TX
    Rick S
    So, I checked my oil level, car running and hot. It's a good 2" above the MAX notch. My guess is, the last service guy filled when not running. Ugghh...
    Is there a way to remove some of the oil without having to jack the car, drop the belly pan, etc? Perhaps a hose down into the oil fill neck and then gravity drain a quart or two?
    Thanks!
    Rick
  2. ncjetskier
    ncjetskier Formula 3
    Jul 7, 2012
    1,416
    Eastern NC
    Chris
    Turkey baster.
  3. vrsurgeon
    vrsurgeon F1 World Champ Silver Subscribed
    Dec 13, 2009
    16,544
    Charleston, SC
    Curt
    As above, turkey baster or syringe and hose. BTDT.
  4. vincep99
    vincep99 Formula 3 Owner Silver Subscribed
    Jun 8, 2009
    1,941
    Had the same problem, I used a siphon pump
  5. 2mmuch
    2mmuch Formula Junior BANNED
    Nov 3, 2003
    326
    Ontario
    Luigi
    I don't think you have to drop the belly pay, the oil drain plug is right under a rubber 3" plug on belly pan.
  6. jlonmark
    jlonmark F1 Rookie
    Mar 29, 2005
    3,204
    Beverly Hills, CA
    Jay
    Hopefully the extra oil didn't get injected and ruin your mafs and sensors. Common mistake on these cars. This might be the exception to the rule of too much oil is better than too little. Too little the light would come on and you could add accordingly
  7. Roadking80134
    Dec 5, 2013
    267
    Spring, TX
    Rick S
