Dreaded 488 blown turbo… | Page 8 | FerrariChat
Discussion in '458 Italia/488/F8' started by Carbon777, Mar 30, 2024.
  1. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,644
    Tampa FL
    @Carbon777 how's the 488 coming along?...up and running?
  2. MANDALAY
    MANDALAY F1 World Champ
    May 23, 2013
    14,709
    AUSTRALIA
    ANGELO
    Yes on full factory No on power warrantee. 2018 488 7 years full factory warrantee no issues. Take proper care of the Turbos , warm up and cool down and they will love you.
    MalibuGuy likes this.
  3. RoyalPink
    RoyalPink Formula 3
    1,576
    Southern Utah
    John D.
    False. FNA covers turbos under power warranty.
    SAFE4NOW likes this.
  4. MANDALAY
    May 23, 2013
    14,709
    AUSTRALIA
    ANGELO
    Well I stand corrected. In Australian they dont.
  5. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    6,062
    Im curious to know the differences and improvements in the turbos from the 488 to the Pista to the F8.
    Are there meaningful improvements in the way of sensor for rotational speed and temperature ?
    Are there new cooling systems to help with shut down heat?
    Are there mechanical improvements to the turbos themselves?
  6. MalibuGuy
    Sep 18, 2007
    6,062
    Do drivers watch the Turbo info screen as they drive? Turbo Boost vs Efficiency ?
    Too bad both screens cannot be viewed at the same time!
    Do the screens help us see if there is a problem with one or both turbos?
    SVCalifornia likes this.
  7. MANDALAY
    May 23, 2013
    14,709
    AUSTRALIA
    ANGELO
    Problem is if your looking at the sceen your not looking at the road.
    I believe the Pista turbos are slightly different. As you know every following model has some sort of improvement
  8. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,644
    Tampa FL
  9. Eric C
    Eric C F1 World Champ
    11,136
    St. Louis, MO
    Eric
    I put suburu turbos on mine
    mdrums likes this.
  10. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,644
    Tampa FL
    Whoop De Do for your Subaru ! ;-)
  11. HD Tuning
    HD Tuning Rookie
    Sponsor
    Feb 7, 2024
    49
    Irvine, CA
    HD Tuning
    The Pista and F8 run the same turbos as the 488. The only difference is they added speed sensors, which read the rpm of the turbine wheel to make sure they don't exceed 160k rpm in an attempt to keep the turbo from exploding. Sadly, the turbo design is just garbage and they tend to fail either way.
  12. MalibuGuy
    Sep 18, 2007
    6,062
    Does the motor need to come out to replace the turbos?
  13. HD Tuning
    HD Tuning Rookie
    Sponsor
    Feb 7, 2024
    49
    Irvine, CA
    HD Tuning
    No, the job is fairly painless.
  14. Eric C
    11,136
    St. Louis, MO
    Eric
    Do turbos only fail on modified cars?
  15. HD Tuning
    HD Tuning Rookie
    Sponsor
    Feb 7, 2024
    49
    Irvine, CA
    HD Tuning
    Sadly no. They pretty commonly fail on stock cars.
  16. Eric C
    11,136
    St. Louis, MO
    Eric
    I know. I just like to hear it. :)
    vraa and HD Tuning like this.
  17. MalibuGuy
    Sep 18, 2007
    6,062
    Thanks for the great info
    What is the issue with the turbos used on the F8/Pista?
    Are the turbo themsleves made from a casting process which has natural air pockets?
    Or is there an issue eith the bearings?
    Ot is it due to owners not understanding the warm up and cool off ?
    Ferrari doesn't make the turbos for these 2
    models. I believe IHI ?
  18. Trev450
    Trev450 Formula Junior
    Mar 11, 2024
    696
    Trevor H
    Yes IHI turbos
  19. hirohawa
    hirohawa Karting
    139
    Los Angeles
    How common is common? I have 3500 miles on my 488. I survived the Z06 LS7 Valve issues with a warranty fix on my heads before they would have allegedly blown. Is there a preemptive/preventative fix for the factory turbos?
  20. MalibuGuy
    Sep 18, 2007
    6,062
    I chose the extended warranty .
  21. MANDALAY
    May 23, 2013
    14,709
    AUSTRALIA
    ANGELO
    Problem with any of the blown turbos is inaccurate or no information why they did.
    But at a guess
    Not properly looked after
    After market modifications
    mdrums and Trev450 like this.
  22. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,644
    Tampa FL
    If your car is stock, no engine mods and you allow the turbo to cool before shutting the car off, you are more than likely not to have issues. It is not common on factory OEM cars and not too common on slightly modded cars. I put almost 10,000 miles on my 488 and never had an issue.
    Cigarzman, SAFE4NOW, MANDALAY and 2 others like this.
  23. forty1
    forty1 Karting
    Jul 4, 2024
    136
    Australia
    Nico
    Friend had one pop for no apparent reason on a stock / low km F8 this year.
  24. MANDALAY
    May 23, 2013
    14,709
    AUSTRALIA
    ANGELO
    You do realise that mileage generally isnt the problem.
    Its abuse.
    Remember the F8 and Pista engines are really dialed up from factory.
  25. forty1
    forty1 Karting
    Jul 4, 2024
    136
    Australia
    Nico
    I wasn't referring to the general problem. Just one individual event.
    But regarding the general problem. IMO it is not the 1990s turbo timer era anymore. And the idea you should have to baby a turbo on a 500k supercar to keep it functional is ridiculous.
    Carbon777 likes this.
