Dreaded CEL | Page 3 | FerrariChat
Dreaded CEL
Discussion in '348/355' started by dahveedem, Mar 25, 2016.
  1. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    That's a good question..though these are burned from stock chips.
    I did some searching and some folks are indicating fouled spark plugs, MAFs and a few other things.
    Eric would need to chime in on the chips.
    One post (will find link) said his car sounded like an american V8.. and that kinda plays here.
    Sent from my SM-G930P using Tapatalk
  2. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    Pulled plugs... 6 and 8 a bit fouled/oiled and I may have overfilled it in the fall. So gonna replace them.
    Btw... 5/8 socket on the Champion plugs installed at last major.
  3. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Ditch the Champions and install some NGKS! Seriously.
    The chips you have now will indeed set codes and turn on the CELs when appropriate.
    I was under the impression that the rough running started with the chip installation. If not then forget what I said about reinstalling the old chips. The engine should run better/smoother than stock with the new chips. I was thinking that perhaps other mods had been made to the engine in order to work with the aftermarket chips and that was the reason for the rough running, but apparently not?
  4. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    Nope. Rough before chips... but with CEL. So no CELs so maybe new plugs will fix rough plus strong exhaust smell.
    And...yah. that's my ultimate goal.. but I'm impatient so Champions it is to test the theory 😉
  5. 3forty8
    3forty8 F1 Rookie
    Apr 25, 2006
    2,713
    San Diego
    Eric
    No. David received a set of chips copied from OEM code. Although the processing speed is faster than the OEM chips, they will absolutely display error codes. His aftermarket chips were throwing a CEL, at least he has a stock baseline now from which to continue troubleshooting.
  6. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,662
    San Carlos, CA
    Mitchell Le
    I would change out those plugs and re-learn the ECU. I had a couple times when fouled plugs were causing me lots of headache.
  7. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    Ok plugs fouled 6, 8, 1, 3. Pretty sure i overfilled it.
    Replaced all plugs.
    Still running rough and i would say rich. Strong exhaust.
    Unplugged the tecu and o2 for heck of. Didnt light the CEL..but did store it plus a 1112 on the 5-8.
    Engine temp coolant. Cleared that. Nothing since that.
    Still sounds like a big v8.
    Next up MAF cleaning.
  8. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Sounds to me like either one or both of your ECU engine temp sensors are dead, or the connection(s) are bad. When the temp sensor circuit is open the ECU thinks that the engine is below 0F, so it really dumps the fuel in to compensate for the dense air.
    Do you still have converters on the car? If so, use an IR temp gun to compare the surface temps of each converter. If one is notably hotter than the other that probably means that bank is running rich. In that case, check the temp sensor and fuel pressure regulator for that bank.
  9. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    No cats. Test pipes with Tubi exhaust.
    Where's temp sensor?
  10. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    There's one for each bank. IIRC. That's why it'd be nice to know which bank you should be looking at. See the diagrams on the Ricambi site or in the parts manual for the locations. I'll see if I can dig up an image in a minute.
  11. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    #61 ///Mike, Apr 15, 2016
    I'm pretty sure that one is located at position 43 in this pic. The manual calls for two, but apparently does not indicate the position of the second one. Seems like it would be in the same position on the other bank though.
  12. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
  13. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Good work David!!!
    Super chips has been around for a while. Whether you gained anything from those is unknown, unless you have a dyno pull from before you swapped out the eproms. Then you could do a follow up dyno, at the same shop, and see what the difference is between the two.
  14. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Awesome thread. Eric is great!
    I agree with the post that recommends using Bosch replacements only. While you're waiting for them to arrive I'd suggest dousing the contacts with DeOxit, since there's a decent chance it's just a bad connection (especially if both are acting up). You can also perform a basic test by checking the actual resistance versus the specified resistance (presumably stated in the repair manual). What really matters is the resistance that the ECUs see-- if there's resistance in a connection the ECUs can't calculate the correct mixture, even if the sensor itself is fine. So testing the resistance at the ECU plug is the preferred test method.
    Good luck!!!
  15. m.stojanovic
    m.stojanovic F1 Rookie
    3,297
    Serbia - Niš
    Miroljub Stojanovic
    #65 m.stojanovic, Apr 15, 2016
    The coolant temperature sensors should measure about 2 K.Ohm at about 25C, more at lower and less at higher temps.
    If removing the coolant overflow hose from the housing, carefully check the hose adaptor (aluminium). Mine was like on the 1st pic below - condition after cleaning out the accumulated crude (it wasn't leaking as it was almost completely plugged). Solution is on the second pic.
  16. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    Wow! That's bad. What parts did you buy?
  17. m.stojanovic
    3,297
    Serbia - Niš
    Miroljub Stojanovic
    #67 m.stojanovic, Apr 15, 2016
  18. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    Sweet..thanks.... our favorite sponsor wants 40each for them.
  19. m.stojanovic
    3,297
    Serbia - Niš
    Miroljub Stojanovic
  20. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Wow-- one of the rare parts for our cars that are actually cheap. No doubt because it is used in other applications. At that price I think I'll pick up a couple to install during the upcoming major service, just for good measure. Thanks, Miroljub.
  21. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    Thanks!
    just bought 2 at that price and paid for Express shipping.
    again -fingers crossed that's my latest issue... but I'm not convinced.
  22. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    Just thinking...how about a throttle body being stuck open?
    During my cleaning process i pulled the big hoses off and looked at them..didnt see any buildup but maybe i jacked something up?
  23. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Assuming you mean the "crossvalve" between the two manifolds. Because the only way a throttle butterfly can be stuck on a 348 is if the throttle linkage fails... because it's a mechanical throttle, just as God intended. ;)
    I'd have to go back and read this thread more carefully to be certain, but IIRC the symptoms you describe point toward a rich condition, which most often means a bad CTS or a bad FPR.
  24. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    Lol..dude you are as bad as Cisco..I'm in acronym hades....
    Cts? Fpr?
  25. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Coolant Temp Sensor/Fuel Pressure Regulator.
