drilled rotors for 355 | FerrariChat
Discussion in 'Technical Q&A' started by billwann, Oct 5, 2005.
  1. billwann
    billwann Formula Junior
    Jan 5, 2004
    324
    Bristol Wisconsin .
    Bill Wann
    Does anyone know where to get a set of cross drilled rotors for a 355 .
    thanks
  2. f355spider
    f355spider F1 World Champ
    18,044
    This place was recommended by another member here...competitive pricing. You might also try our sponsors...like Nick's and also Ricambi America.
    http://www.interautoparts.com/
  3. Tifoso1
    Tifoso1 F1 Rookie
    Nov 18, 2003
    2,602
    Pacific NW
    Anthony C.
    If you don't know much about brakes, I would recommend doing a little research on them, such as the differences between slotted rotors vs. drilled rotors. Sites such as: www.stoptech.com and www.************
  4. mgtr1990
    mgtr1990 Formula 3
    Mar 30, 2005
    1,580
    Naples Florida
    Martin Graham
    I got the Brembo package which was Cross Drilled Rotors,Red calipers and Stainless Steel lines from Norwoods in Dallas thety are a Brembo distributor it fixed the brake squeel and look great.
    Martin
  5. f355spider
    18,044
    I just changed from stock pads to Porterfield R4S pads to eliminate the squeal.... it is several thousand dollars less...but I won't be able to stop as well as you! ;)
  6. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    check the surface around the holes very carefully. If you track the car or drive it very hard, there is a good possibiliity that you might see cracking around the holes.
    If you have cracks, this might be a good time to switch to slotted. Don't worry about the other end of the car, you can go to slotted when they require replacing.
    hth,
    chris
  7. mgtr1990
    mgtr1990 Formula 3
    Mar 30, 2005
    1,580
    Naples Florida
    Martin Graham
    AND!!!! you wont have cool Red Calipers!!!!
  8. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
  9. mgtr1990
    mgtr1990 Formula 3
    Mar 30, 2005
    1,580
    Naples Florida
    Martin Graham
  10. lauris
    lauris Formula Junior
    Jul 27, 2005
    281
    Glasgow
    Scott Laurie
    my 911 ones need doing as they are cracking around the holes,,, car is lightly tracked,, although brake late like a mad man on occasion,,,,
    but they look good !
    others have same probs,,,, and ones with holes more prone to grooving !
    cheers
    scottie
  11. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    #11 Mike C, Oct 6, 2005
    Yes, but not on my own car. My 308 has black Brembos on the front, a sort of "stealth" upgrade.
  12. mgtr1990
    mgtr1990 Formula 3
    Mar 30, 2005
    1,580
    Naples Florida
    Martin Graham
    #12 mgtr1990, Oct 6, 2005
    They look good I like the black for that wheel and color, I have a TR and want to do something with it in the wheel area rotors calipers and Non stock wheels
  13. vincer77
    vincer77 Karting
    Dec 12, 2003
    71
  14. 1badboy
    1badboy Formula Junior
    Dec 11, 2004
    290
    Hermosa Beach, CA
    Eric Rayl
    #14 1badboy, Oct 6, 2005
  15. enjoythemusic
    enjoythemusic F1 World Champ
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    #15 enjoythemusic, Oct 7, 2005
  16. f355spider
    18,044
    Because on the 355 it was a factory option from 98 on...
  17. Pelle75
    Pelle75 Rookie
    Jan 11, 2005
    24
    Sweden
    Per E
