Driver Power Window came loose | FerrariChat
Discussion in 'California(Portofino)/Roma(Amalfi)' started by agustinush777, Apr 2, 2017.
  1. agustinush777
    agustinush777 Rookie
    Aug 29, 2014
    40
    Jakarta
    AG
    Yesterday I got caught in a heavy rain while joyriding with my son and upon opening the window I heard a streaking sound between the glass and the rubber strip.
    Then the window got stuck in the up position and when I tried to roll it down I could hear the motor was winding but the glass wouldn't roll.
    So I supect something or maybe a gear had stripped and didn't hook up the mechanism.
    Has anyone experienced this before and got any solution? I am free on sunday and planning to take a peek myself behind the door card. Any advice on how to remove the door card? Any airbag warnings I should pay attention to?
  2. agustinush777
    Aug 29, 2014
    40
    Jakarta
    AG
    [​IMG][​IMG][​IMG]
    Door card is off and it turned out to be a stripped power window motor gear. Window regulator looks brand new still. I bet the gear is made of plastic. A new motor is coming first thing monday morning. [emoji482]
  3. cranky
    cranky Karting
    Aug 7, 2011
    68
    Cincinnati
    Michael S
    It's Italian. Things breaking just adds to the character.
  4. BillyD
    BillyD Formula 3
    1,828
    Pacific Northwest
    Bill
    So The center of the door and speaker cover just pull off?
    Screws for door card in above locations?
  5. agustinush777
    Aug 29, 2014
    40
    Jakarta
    AG
    +1
  6. agustinush777
    Aug 29, 2014
    40
    Jakarta
    AG
    Correct. Needs a steady and firm pull. Invest on an orange plastic prying set used by car audio shop. Screws are all visible and they are all lightweight alum screws. However, 1 screw is hiding just right behind the door handle gotta to tilt the door card from below to see it. Then lift the whole door card upward.
  7. 4th_gear
    4th_gear F1 Rookie
    Jan 18, 2013
    4,425
    Michael
    Kudos to you on your DIY diagnosis and repair!
  8. agustinush777
    Aug 29, 2014
    40
    Jakarta
    AG
    Part did not come. Ferrari dealer refused selling part without instal. [emoji109]Hello ebay.
  9. agustinush777
    Aug 29, 2014
    40
    Jakarta
    AG
    It is in ready to instal. Will doc the installation process [emoji120]
  10. agustinush777
    Aug 29, 2014
    40
    Jakarta
    AG
    Got me some help to dismantle the window regulator.
    Doorcard is off :
    Next is taking off the glass by removing the torq screws on these 2 holders :
    Glass is off next is to take out the regulator. It is imperative to remove the whole assembly in order to fit the new motor due to the alignment of the teeth :
    Motor is off and the gear turned out split from the base :
    All done and reassembly is just the reverse.
    [emoji482]
  11. 4th_gear
    4th_gear F1 Rookie
    Jan 18, 2013
    4,425
    Michael
    Thanks very much for showing photos of the repair process.
    The split gear looks gruesome - looks like something cut right into the gear and "decapitated" it. Were you able to find out how this happened in case it might also affect the replacement part?
  12. agustinush777
    Aug 29, 2014
    40
    Jakarta
    AG
    My pleasure...
    According to the dealership it is a very common problem on the Calis and 458s in the tropics. Here and Hongkong where it occurs most. Maybe they should switch vendor to Denso. My 10 yr old Suzuki's electrical is still performing flawlessly. [emoji85]
