Driver Side Seat Stuck | FerrariChat
Discussion in '348/355' started by rumster, Jul 19, 2011.
  1. rumster
    rumster Rookie
    Feb 5, 2007
    26
    I was lowering the top in my F355 and the driver's seat became stuck in the forward position. Also, the roof would not engage past the "beep" when pushing it back. It will return to the closed position just fine. Also, the passenger seat and windows operate normally. Could this be a bad sensor? As an aside, the car went through an emissions test the day before I attempted to lower the top. Coincidence? Or could something have gotten scrambled in the ECU?
    Any thoughts would be appreciated. For what it's worth, I hope this does not happen to anybody else. I had a terrible time trying to extricate myself from the driver's seat while pinned to the steering wheel!
  2. plugzit
    plugzit F1 Veteran
    7,779
    Redondo Beach, CA
    Bruce Bogart
    Maybe the typical potentiometer problem?
  3. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,573
    San Carlos, CA
    Mitchell Le
    You can pull the connector to the motor and apply 12v to the pins to see if the motor works or not. I have a 12V motorcycle battery I drag around for that purpose. If the motor works, and the seat does not respond to the switch action, you pull the switch and test its functionality by itself. If the switch works, then the remaining culprit is the top ECU.
    I don't see how a bad pot would disable the seat from moving, but there are many things in this world I don't know about.
  4. X11OUD
    X11OUD Formula Junior
    Mar 22, 2008
    729
    Manchester, England
    Neil
    The System monitors the seat position for the fully forward and fully back values, if it sees the fully back value and your seat is forward, it will not move the seat back.
    Mine has been like this since last summer, I moved the variable resistor off the pot to just under the front of the seat to adjust it myself when required. I will at some point get the time to put in my new pot.
  5. rumster
    rumster Rookie
    Feb 5, 2007
    26
    Okay, the motor is working so that is positive. In fact, it seems like the program command wants the seat to continue to move forward--except that it is already all the way forward. I believe that the roof, windows, and seats are all tied together within the system, but maybe there is not recognition of where the driver's seat is within the "top down" process.
    I had a situation a few months back where the driver's window would not operate on my Vantage, but all that took was a Flash Reset on the ECU.
  6. roadracer311
    roadracer311 Formula 3
    May 6, 2009
    2,398
    San Francisco
    Paul
  7. yelcab
    Nov 29, 2001
    13,573
    San Carlos, CA
    Mitchell Le
    As Neil pointed out to me above, the seat potentiometer may be a culprit in this instance. And, because the motor works, you can actually remove the seat in order to swap out the seat potentiometer. Good luck.
  8. rumster
    rumster Rookie
    Feb 5, 2007
    26
    The prior thread was helpful--going to get the part ordered tomorrow. It's frankly too hot to drive that car with the top down anyway. Into the triple digits here in Chicago!
  9. roadracer311
    May 6, 2009
    2,398
    San Francisco
    Paul
    It's easier to repair the part than replace it. You don't have to completely remove the seat pot to repair it.
    I repaired mine just over a year ago (as shown in that thread) and it's still working perfectly.
  10. rumster
    rumster Rookie
    Feb 5, 2007
    26
    I actually called the dealer and they mentioned that as well.
