drivers side hazards not working | FerrariChat
Discussion in '308/328' started by spike308, Sep 17, 2009.
  1. spike308
    spike308 F1 Rookie
    Nov 8, 2003
    4,774
    Austin TX!
    Mike Z
    After a contact in the light stalk went out on me last evening, I tried driving with the hazards to get to a friends house (I don't recommend driving your car in the dark without lights!). Got that all fixed up, to realize:
    the drivers side hazards do not flash (front and back). Blinkers are fine, just not the hazards. I searched, could not find something specific for this.
    Switch problem?
    (BTW, I have Birdman's fuse box installed)
    thanks!
  2. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,843
    Cerritos, CA.
    Mike, it's funny you have this problem because my passenger side hazard don't work either both front and rear but, if you turn signal on either direction then the hazard works on both side. Somebody told be that the connection under the hazard switch might be loose or has bad connection. What do you think.
  3. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    Wiring diagrams show turn signals go through hazard switch. If one side hazard is out, that turn would also be out. Several posts lately with bad switch contacts, cured with contact spray. Occasionally the push-on connectors back off the hazard switch and need a gentle push-back.
    _________________________
    http://www.ferrari308gtbi.com/
  4. spike308
    spike308 F1 Rookie
    Nov 8, 2003
    4,774
    Austin TX!
    Mike Z
    any advice on how to pull out / remove the hazard switch?
    thanks
