driving in cold temperature | FerrariChat
Discussion in '456/550/575' started by modificato, Nov 3, 2015.
  1. modificato
    modificato Rookie
    Oct 20, 2009
    46
    I live in Canada and I drive my gated 456m as late as i can usually up to first snowfall. I was explaining to someone how it is a very different car in November with temperature ranging from 5 to 10 degrees celcius than July. The car is much more fun and unbelievably responsive in colder weather.
    I was wondering why that is?
  2. tazandjan
    39,175
    If you are talking about the engine, the colder, denser air does give a bit more hp.
  3. AVIMAX
    AVIMAX Formula Junior
    Aug 5, 2014
    710
    Toronto
    Ryan
    I agree, I really like driving my 550 when it gets cold, and I also drive until it gets salty. Something even more special about a V-12 Ferrari out and about when most people have already put their summer cars away.
  4. redcaruser
    redcaruser Formula 3
    Apr 8, 2012
    2,426
    switzerland
    daniel
    At a constant air pressure a change in the temperature of 20°C to 4°C makes a difference in hp from about 2.8%. That would be in the case of a 456 approx. 12hp.
    BTW: A change in barometric pressure of 1013hPa to 1042hPa makes also a difference in hp from about 2.8%.
    Conclusion: with a little bit luck you can tune your car for no money.
  5. tifosi_
    tifosi_ Formula 3
    Sep 24, 2013
    1,863
    Toronto
    Clyde
    The engine drives better but the tires don't particularly like the colder weather
  6. AVIMAX
    Aug 5, 2014
    710
    Toronto
    Ryan
    That's why I switch from my Michelin PSS to Continental DWS once the temps drop, makes a huge difference. With the Michelins, the traction control is constantly intervening, with the all seasons, no problems. The MPSS turn into hockey pucks once the temp drops to single digits (Celsius). I happen to have 2 sets of wheels (car came with both), so it's easy to swap in the garage.
  7. fatbillybob
    Aug 10, 2002
    29,022
    socal
    And so.....if you want the pop of the winter dense air in the summer what you do is run straight water or water methanol in the windshield reservoir. You plumb the output of the reservoir to atomizers exiting into the intake and add requisite electronics. The atomized water will cool the intake charge and give you a nice horsepower boost you can actually feel at the seat of your pants.
  8. Sandy Eggo
    Sandy Eggo F1 Rookie
    3,636
    Encinitas, CA
    Rick
    Thermal efficiency of an internal combustion engine is also improved in cooler ambient temperatures. I think that's what daniel was getting at with his example.
    The cooler, denser air does create more drag though. So your 0-60 times might be a wash. :^)
